Technical Can You Use a Brake Light Switch for a Nuetral Safty Switch?
Discussion in 'The Hokey Ass Message Board' started by brigrat, Dec 6, 2019.
  1. brigrat
    brigrat
    from Wa.St.
    Can You Use a Brake Light Switch for a Neutral Safty Switch, will it carry the load?
  2. Rex_A_Lott
    Rex_A_Lott
    The load is not the problem. The switch is normally shut, held open when the brake pedal is up. Pushing the brake pedal lets the plunger come out, allowing the current to flow.
    You want a switch that is opposite of that , I believe.
    Normally open, held shut when in reverse. Good Luck
    Black_Sheep and ted kovacs like this.
  3. theboss20
    theboss20
    Any switch can be used with a relay and if you use a five tab cube relay you can wire it to function anyway you want...
    Sent from my iPad using Tapatalk
  4. 57 Fargo
    57 Fargo
    Unless i misunderstand what you wrote, you are backwards. most brake light switches are normally open, closing when brakes are applied to complete a circuit to turn lights on. Same as Neutral safety, normally open closed in park or neutral.
    brigrat and trollst like this.
  5. Weedburner 40
    Weedburner 40
    You can use a push ****on starter switch but, it'll only work in park.
    swade41 and brigrat like this.
  6. 2OLD2FAST
    2OLD2FAST
    from illinois
    A 50's plymouth lever type brake light switch is normally open , like mentioned , you may need an additional relay in the circuit ...
    brigrat likes this.
  7. greybeard360
    greybeard360
    You could use it but would need a tab on the clutch pedal to depress it when you push in the pedal. That was the way my OT 69 Firebird was from the factory. IIRC they used the same switch to do each function.
    Just looked it up. They actually had a lever type of switch like some of the old GM cars used.
    brigrat likes this.
  8. Rex_A_Lott
    Rex_A_Lott
    I did misunderstand, I thought he was wanting a switch to turn on the backup lights when it was in reverse. What I said about the function of the brake light switch is correct, as I understand it. The "normal" position of the switch is where it sits when it is un actuated, even though we consider the normal position of the brake pedal is not pushed, when its sitting there in that position, the plunger is pushed in. Its a normally shut switch.
    brigrat likes this.
  9. radarsonwheels
    radarsonwheels
    from Philly
    I am reading some confused sounding answers here.
    All the brake light switches I’ve seen on cars connect the two wires when the ****on is not pressed- so the circuit is open when the brake pedal is resting up and pushing the switch.
    This kinda switch would work as a NSS but I would use it as the ground leg on a bosch relay. Then feed the input with the starter switch/****on. That way you can hit start all you want but it won’t crank unless the brake is pressed. That would be similar to a stock setup where the NSS is a ground switch that is engaged only in N or P in the trans or an aftermarket shifter.
    I guess you could also use the key as only the run circuit and divorce the crank circuit. Then feed the starter ****on from the brake light circuit- you can hit start all you want but it won’t start unless the brake lights are on. This way would avoid a fancy modern bosch relay.
  10. brigrat
    brigrat
    from Wa.St.
    What I have going on is a Tremeck 500 (5 speed) WITH a short shifter location, when you move the shifter to a forward location you loose the factory Tremeck NSS, you have to plug it off. First choice is to mount posted pic of a brake light switch to mechanically operate as a NSS on the clutch pedal under dash. I think you have answered my question, NOT a good idea without a relay. If I have to buy the switch, buy a relay I might as well get a true NSS off a Mustang? that will not need a relay?
  11. woodiewagon46
    woodiewagon46
    from New York
    I would give Lokar, the shifter people and purchase the small ****on type switch from them.
    brigrat likes this.
  12. Boneyard51
    Boneyard51
    It may be a little tricky using a simple switch such as that as it has to be activated in neutral, if it’s a standard and it’s on the shifter the range of the switch would have to go from 1st and 2nd and neutral and 3rd and 4th and neutral. A micro switch with a little lever would be a better choice or a ball switch. If on a automatic, it would need to work in park and neutral. Those would require some trick stuff to work properly. If you are going to use it as a “ safety” switch on the brakes or clutch it should be no problem.
    Bones
    brigrat and deathrowdave like this.
  13. Atwater Mike
    Atwater Mike
    Napa has a truck/tractor starter ****on that has a 30 amp rating, no relay required.
    Also has a threaded neck on one end, bracketing made easy...Under $20? Last I checked.
    brigrat likes this.
  14. BadgeZ28
    BadgeZ28
    from Oregon
    I think it was a mopar with a 727 where the switch just opened the ground at the solenoid so it would not start. A simple rocker switch will work. You will need to construct a bracket.
    brigrat likes this.
  15. 57 Fargo
    57 Fargo
    I'm so confused... not sure if we are saying different things or the same...
  16. Atwater Mike
    Atwater Mike
    The same, only different.
    57 Fargo likes this.
  17. krgdowdall
    krgdowdall
    from Alberta
    I am using the same switch for Brake light and Clutch switch, ( Napa #SL169 ) however it was originally used for Brakes.
    GM used a heavier switch for the Clutch switch. Power was routed through the ignition SW, Clutch switch to the Start Solenoid, which requires higher current than the brake lights. Manufactures don't generally give current capacity of the switches but brake lights are wired with 16 or 18 ga wires. The Start wire on a Solenoid is 10-12 ga. with a lot more current capacity. If you decide on using it for a Neutral Safety Switch, use a 30 amp relay to power the solenoid, or the switch would not last very long.
  18. Budget36
    Budget36
    Ok, the older lever type switches on -55-9 Chevy trucks (others too) are spring loaded. The switch is on the closed (current p***ing/short/etc, however you want to say it) as you pull the switch out of the box.
    This would be considered a NC (normally closed) switch.
    When you install the switch you have to pull the lever back and put it behind the pedal rod. This opens the switch (stops current flow like cutting a wire).
    So when the pedal is at it at-rest position, no current can flow through the switch, when you depress the pedal, the spring loaded action follows the pedal movement and "closes" to allow current to flow and light up the brake lights.
    Most of the later model vehicles are similar, but the switch actuates a micrositch built inside, and you can hear a little "click" as you depress the pedal and the switch closes.
    Personally I don't see an issue using this type of switch on a manual transmission actuated off the clutch pedal.
    I think it'd be a pain to try to make it work in an automatic ****** though.
    brigrat and Boneyard51 like this.
  19. 57 Fargo
    57 Fargo
    Now I understand my misunderstanding.....those switches are normally closed but held in the open position normally!!
    brigrat, Hnstray and Boneyard51 like this.
  20. Budget36
    Budget36
    Just like Mike said, the same but different, little sideways and maybe backwards too;)
    Boneyard51 and 57 Fargo like this.
  21. Ebbsspeed
    Ebbsspeed
    Configure it to work with the clutch pedal, then you don't have to be concerned with adapting anything to the transmission shift mechanism. Both normally open and normally closed types of switches can be used, you just need to build the switch activating clutch linkage accordingly.
    If you've got a hydraulic clutch then plumb in a hydraulic brake switch.
    brigrat likes this.
  22. Russco
    Russco
    from Central IL
    I have a pressure switch activated by my hydraulic clutch to complete the starter circuit. The original switch lasted a couple years the new ones don’t seem to do as well. One day I’ll get around to wiring in a relay. Until then I can change them out in about 2 mins.
    brigrat likes this.
  23. David Gersic
    David Gersic
    from DeKalb, IL
    Black_Sheep and brigrat like this.
  24. Mr48chev
    I can see the concept of the neutral switch on the 5 speed but have driven GM stick rigs with the clutch pedal since Dec 68 When I got home from Nam and picked up my special order 69 Cutl*** with 4 speed and am so used to it that I never consider putting a rig in neutral to start it unless I am working on it. Either way the rig won't start in gear and that is what you are after. The other option is a push ****on you have to push with your left hand while turning the key with the right that makes you think about what you are doing and either have it out of gear or push in the clutch.
  25. Al's.C.D.T
    Al's.C.D.T
  26. RMONTY
    RMONTY
    Alot of microswitches with an arm or leaf on them suitable for this application have 3 terminals. A common, NO and a NC. Easy peasy! And as said, wire it through a relay if you have an amp draw more than the switch is rated for.
    brigrat likes this.
  27. brigrat
    brigrat
    from Wa.St.
    Thanks Al's.C.D.T those can intimidating if you don't wire them all the time!
  28. Black_Sheep
    Black_Sheep
    Just to be clear, your relay schematic prevents the engine from cranking unless the brake is depressed?
    I like to save this kind of stuff for future reference...
  29. David Gersic
    David Gersic
    from DeKalb, IL
    Right. A brake light switch is Normally Closed, and is held open by the brake pedal at rest. Press the brake pedal, the open switch closes, providing 12V to the lamps.
    This circuit provides 12V to close the relay, enabling the ignition switch to crank the starter.
    You could adapt this to a clutch pedal switch for a stick car, or a transmission mounted Neutral Safety Switch.
  30. brigrat
    brigrat
    from Wa.St.
    I probably wasn't clear but yes I am planning on mounting it on the clutch pedal. Whether it's opened or closed shouldn't matter as I can mount it over or under pedal center line of pivot shaft.................................................
    Black_Sheep likes this.
