Art & Inspiration Candy, Lace, Flake, Flames... wanna see WILD custom paint...
Discussion in 'The Hokey Ass Message Board' started by kustombuilder, Apr 13, 2008.
  1. elspock84
    elspock84
    from waukegan
    few snack tables i did last week.
  2. Cragar
    Cragar
    I love this thread it is the best you guys are the best form of inspiration I have done a bit of this sort of stuff in the past and it make me want to do it again thanks
  3. No surprises there! I've gotta agree too.
    Sooooo..... How's the Rivi going Craig?
  4. MUNCIE
    MUNCIE
    from Houston
    :cool:Right on! Seriously thinking about laying some patterns on my roof. I might want to get in touch with him when he heads back this way.:cool:
  5. VintageConcepts
    VintageConcepts
    elspock84 That's some real sweet work you do there.
  6. theHIGHLANDER
    theHIGHLANDER
    Dealing with an anomaly very similar right now. All the same base, clear, same drying time on everything, low film build. The clear stayed soft on several parts, got hard on others, even cured in the cup overnight. Days went by, lots of heat, nothing made it harden up. 1st thought, not enough catalyst, right? Wrong. Why did some parts get hard as a rock? Why did it kick in the cup? Mixed up a few oz of clear/catalyst in a 50/50 mix, then about 150% reducer. Sprayed it over the offending soft parts and let em sit overnight again. Hard as a rock now, and all the way through to the base. Now that thin ****ed up layer wants to lift. My whole take on this is the temps dropped as I was going along, add to that excess humidity. The thin 1st coat didn't "kick" because there was not enough VOLUME of material on those panels and they were cool enough to slow the reaction...permanently. The catalyst 'mist' I applied simply made it hard enough to sand off easily, so now I have that to face before picking up where it left off. I've been consumed with this for more than 5 12hr sessions and I'm going to walk away from it for a couple days.
    As custom painters we often bend or break the rules. Usually when we do it all comes out exceptional. Then there's times we follow all the rules, directions, established protocols, give all the love and effort we can, then it turns around and shoves a roll of sandpaper up your ***! All of this material is subject to failures, some fatal (complete redo) some just more aggravating than anything. 1oz too much or too little will either make or break the gig. The other major enemy is the base coat and reducers required. I'm probably at the point where I'll start using a drop of catalyst in the base from now on. I was advised by a PPG tech that an oz added to 1qt of ready to spray base will prevent undue crazing for repairs and multi layers. He recommended DX57 (?) or 50-something designed for a direct gloss material. I usually have no issues but now n then they show up like that loser you know always beggin for attention or $$$. Sometimes I truly hate this ****...
  7. elspock84
    elspock84
    from waukegan
    Thanks :) I see you from beach park ;) I'm form Waukegan
  8. VintageConcepts
    VintageConcepts
    Yeah, you'll see me riding in my 54 around. This thread is full of creativity…thanx for contributing.
  9. Some things I just did for a little local art show. Sportster tank and another skateboard.
  10. 56gasser
    56gasser
    from lower al.
    Can someone show me whiteflake over a white base looking for ideas!!
    Thanks
  11. Never seen a white flake before. The closest being abalone which usually has a pink and gold tone to it. Over white I usually use either a clear flake, white ice pearl or a crushed gl*** to keep it as white as possible.
  12. CARLOS8A
    CARLOS8A
    from waukegan
    Here is the roof on my 64 Pontiac 😎
  13. tikiwagon13
    tikiwagon13
    Abalone over white, it's subtle but in the sunlight it pops.
  14. nitrobrother
    nitrobrother
    Go to a Ford dealer and check out the White Platinum paint on a Fusion. I dislike white as a car color, but I like White Platinum.
  15. VintageConcepts
    VintageConcepts
    Flames I did about a year ago. Played with some kandy colors but picture turned out kinda bad
  16. Snake hit
    Snake hit
    from calif. LA
    Had another set of Harley fatbob tanks painted, was looking for a change from the original 1995 FLSTN special look, so had the same colors left over from my Riviera build. Went with the same colors and pinstripping so wouldnt have to change the fenders. The look I was going for was the 1965 style FLH Electra Glide. had them painted cleared blocked striped and re cleared then buffed and added 1965 badges, looks alot better and the retro look I was after. Now for the headlight nacelle and Electra Glide fender script.
    [​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
  17. Flootiebuell
    Flootiebuell
    First attempt......
  18. chris98006
    chris98006
    from Seattle WA
    I like it! Love the way you did the lines.
  19. ugotd8
    ugotd8
  20. kustumizer
    kustumizer
    from Alton,NH
    These pictures are from my stepfather when he stopped by Kelsey Martins shop to check out some bikes he was building.
  21. kustumizer
    kustumizer
    from Alton,NH
    a pedal car that my stepfather and his fiend Dave hussen painted
  22. Speedchop
    Speedchop
    from Sweden
    Really cool thread! I'm about to do some dirty-work in the garage so it's truly inspiring.. I've almost browsed through the whole thread in one go! Keep 'em coming!
    Speedy
  23. elspock84
    elspock84
    from waukegan
    what ive been working on the last few weeks.
  24. MUNCIE
    MUNCIE
    from Houston
    Does anyone know if there is a abalone that gives off more of a blueish hue rather then this green?
  25. BarryA
    BarryA
  26. Louie S.
    Louie S.
    Does anyone know of a place to get a color called pineapple pearl? My dad had a car in 53 painted this color and I would like to find it. I have searched the net with no luck.
  27. MUNCIE
    MUNCIE
    from Houston
  28. Louie S.
    Louie S.
    That's the color, just can't find one out there, thought maybe someone would remember a color code or name from back in the day.
  29. slammed
    slammed
  30. Butch Clay
    Butch Clay
    The talent on this thread is unreal!
