Hot Rods Canister fuel filter
Discussion in 'The Hokey Ass Message Board' started by mohr hp, May 11, 2025.
  1. mohr hp
    mohr hp
    from Georgia
    IMG_4676.png Any reason I can't use the old style (Fram) canister fuel filter downstream/after my mechanical fuel pump? I have no electric pump and it would serve as my only fuel filter. I'm trying to eliminate a couple rubber hoses, and I like the sevriceability. Thx.
    Tow Truck Tom and swade41 like this.
  2. I think it would work just fine. Medium Duty Chevrolets and GMC trucks used a set up with a canister filter very similar to yours. The only difference in their design, the filter was on the suction side. I’m just curious, why are you putting on the pressure side?
    Tow Truck Tom, swade41 and mad mikey like this.
  3. mohr hp
    mohr hp
    from Georgia
    Since I only have the mechanical pump, I figure it would struggle with the filter on the suction side. I know they're usually used downstream of electric pumps.
    Truckdoctor Andy likes this.
  4. That housing is a bit over kill for a mechanical pump, but you can run a Wix 33900R filter in it which is 5-6 microns worth of filtration. That's what I run inside mine.
    bobss396 likes this.
  5. jimmy six
    jimmy six
    I’ve used them for year’s between the pump and carbs. All the high performance engines had 3/8” hard line. I did doctor the fittings a little and they did not leak. 5/16” line is very adequate for street use as my dual quad system has 5/16”.
    Tow Truck Tom, loudbang and oldsmobum like this.
  6. mohr hp
    mohr hp
    from Georgia
    Thanks guys, I think I'll give it a shot.
  7. bobss396
    bobss396
    I have a couple of the smaller Holley filters that take the old Ford fuel pump elements. Those are great for tight spaces.
  8. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    Great looking and functional piece to be seen under a hood.
    :p Just hope the block is Orange:rolleyes:
