Projects Can't afford a 32 3 window, make one.
Discussion in 'The Hokey Ass Message Board' started by Hot Turkey, Jan 11, 2009.
  1. oldrodder43
    oldrodder43
    I'm kinda like you, I spend a great deal of time with a grinder too. Difference is ---------I hate it! haahaaa. Perley
  2. onlychevrolets
    onlychevrolets
    the quality of work you are doing is the best.... you are one bad *** with a hand held grinder.....you have found your true calling. Keep posting...it's making me want to get back on my 51 Pontiac.
  3. Hot Turkey
    Hot Turkey
    Did prep and prime work all day. Got the transmission painted, had to use etching primer on the aluminum case and finished it with the cast paint. I hung as many parts from the ceiling as I could and still walk around them. Got a good coat of epoxy primer on, then I hit them with several coats of high build urethane primer. I see many more hours of sanding in my future.
    Just hangin out, all wore out!!
  4. captain scarlet
    captain scarlet
    from Detroit
    Wow keep going I am having a great time following your build:D
  5. Hot Turkey
    Hot Turkey
    Oh ya, I spent some time on the spindles to. Did I say I don't like cast markings? lol
  6. lorodz
    lorodz
    wow all the parts look great .....your at the home stretch...
  7. Hot Turkey
    Hot Turkey
    Put in some work today, primed more parts. Tomorrow I hope to shoot some black paint...
  8. wlspdshop
    wlspdshop
    from Missouri
    I can't wait to see more!
  9. Salty
    Salty
    from Florida
    Your alot like me inasmuch that I wholeheartedly dislike cast flash....
    I've spent alot of time (like you) grinding stuff down to get it smooth....the biggest difference, on your project you'll be able to see the detail work when your done...
    Mine will all be hidden under the fenders....oh well...
    Looks awesome H.T. I remember when I did the ceiling hanging trick...I never really realized how many parts were in a ch***is till I hadda paint em all!
  10. Hot Turkey
    Hot Turkey
    My friends think I'm crazy to spend all the extra time cleaning up every little detail. I'm going the leave the rust pits in the rear spring leaves, kinda gives it some caricature. Even if it had fenders I would have to clean up the castings, just couldn't sleep at night. I know, I have issues.
  11. neonloverrob
    neonloverrob
    from newton, ks
    All that grinding/sanding will pay off!! I'm the same way. It ****s *** at the time (D.A. pads don't last long either) but when you're finished and it's all shiney people can't nit pick it to death. Cool car!
  12. Hot Turkey
    Hot Turkey
    Tell me about it! I have gone through hundreds of them! I killed two gallons of primer and many other supplies. I sure do understand why good paint jobs cost big bucks!!
  13. Hot Turkey
    Hot Turkey
    More primer and.............................Black!
  14. Hot Turkey
    Hot Turkey
  15. Hot Turkey
    Hot Turkey
    That's it for today. Night........
  16. lorodz
    lorodz
    looks real good what paint did you use single or 2 stage paint....
  17. the metalsurgeon
    the metalsurgeon
    from Denver
    lookin good ....keep pressing on with the good work
  18. Hot Turkey
    Hot Turkey
    Single stage on all the parts. It's so much easier that way.
  19. lorodz
    lorodz
    what brand paint ....
  20. Hot Turkey
    Hot Turkey
  21. lorodz
    lorodz
    nice it looks like it layed out very smooth....
  22. Hot Rod Michelle
    Hot Rod Michelle
    Hot Turkey, the '32 Three Window has for the longest time been my ultimate hot rod. That said, as a rule, I don't believe in gl*** cars. However, your awesome coupe almost makes me want to change my mind. I really like all the attention to detail, that you have put into the making of your coupe.
    I too cannot afford that '32 Three Window that I have so badly coveted. So instead, I decided that I could maintain my anti-gl*** edict while having a cool hot rod, simply by compromising and opting for a Model-A coupe instead. Although, now those too are being reproduced in gl***.
    For what its worth, keep up the good work. Your car already looks like its going to be killer.
    Cheers,
    Michelle
  23. Hot Turkey
    Hot Turkey
    Thanks, if I could go back in time 4 years ago when I got this hair brained idea, I would go with the Model A. I have gone so far over budget on the build that I could have built a bad *** A. Sure, I could have done this car much cheaper by cutting corners and using a Ch*#y motor but that's just not my nature. Don't tell my wife but I'm stashing parts for the next one.
  24. tedley
    tedley
    from canada
    Personaly...i like a Ford in a Ford.
  25. Hot Turkey
    Hot Turkey
    Can I get an Amen!
  26. Smokin' Joe
    Smokin' Joe
    Amen!!!
    By the way... I only THOUGHT I was psycho when it came to casting marks. =)
    You, sir, are my new hero
  27. Anderhart Speed
    Anderhart Speed
    Hey Hot Turkey, I know this is a stupid question and I should definatly know this, but I don't, and I admit it. Where did you get those valve covers and what are they? I built a nasty high strung 306 out of a 289 for my 30 A' coupe and did a little searching for some finned al valve covers and didn't come up with anything, so I settled for a set of old cast M/T's. Also, how much rocker clearance do they offer? for instance, do you know if they would clear a 1.6 roller? Thanks, I appreciate it.
  28. Hot Turkey
    Hot Turkey
    The whole day was spent wet sanding wish bones, steering column, rear bones and axle. If it stops raining, they will get paint tomorrow.
  29. Jimmy Tee
    Jimmy Tee
    You are coming along great with this build. I'm really enjoying it. I just can't wait for my Frame & parts to get over here from the States so I can get going as well. You have inspired me.
