Technical Can't find these
Discussion in 'The Hokey Ass Message Board' started by mcmopar, Mar 17, 2022.
  1. mcmopar
    mcmopar
    from Strum, wi
    These are the lights for my 37 Dodge truck gauges, they are 3/4, diameter everything I find is 5/8. If I find the 3/4 it's the large bulb and I need the small one they can be modern wires just need to find them. I should say the clips are a 3/4 diameter. Anyone have a place? 20220317_084345.jpg 20220317_084334.jpg 20220317_084325.jpg
  2. It doesn't look like you need complete new sockets. Just put new wire in it. Go to this sight Rhode Island Wiring Service Inc. and go to supplies. You can buy just the Connecter ****on as well as correct color coaded cloth wire by the foot or the roll. It's as easy as that.
    loudbang, anthony myrick and hrm2k like this.
  3. 36and63
    36and63
    from Wisconsin
    hrm2k likes this.
  4. HOTRODPRIMER
    HOTRODPRIMER
    And closer to home you can find the new replacement pigtail wire kit (as seen below) at your local NAPA auto parts store. HRP
  5. Hollywood-East
    Hollywood-East
    I won't tell anyone, If you don't...
    Bob Lowry and VANDENPLAS like this.
  6. Carquest and other parts stores have complete sockets w/pigtails or just the pigtails to replace yours. Here is thread I did on redoing some tail lights a few years ago
    Tech? Refurbishing Swap Meet Tailights | The H.A.M.B. (jalopyjournal.com)
    Just a pigtail. Can be bought in many configurations
    For an internet search use the terms AUTOMOTIVE WIRING PARTS and/or PIGTAILS or SOCKETS
  7. I added pigtails
    NAPA had em
    egads and Tman like this.
  8. akoutlaw
    akoutlaw
    Those look like the old pickup license plate light bulb holders from the 70,s on back.
  9. ekimneirbo
    ekimneirbo
    Tips from an electrically challenged individual. :D
    Won't they be 6 volt bulbs ? You can probably derust what you have by soaking it for a day or two in some citric acid and then rinsing it real good. Solder some new wires on.
  10. If all you need to replace is the wire and contact ****on, a lo-buck and easy to get alternative is a steel pop rivet body. Use a suitable size rivet (probably a 1/16" or 3/32"), remove the mandril, then crimp the rivet body onto the wire with a little bit of wire protruding above the rivet flange. Solder the wire/flange junction for your contact ****on and reinstall. If you want a corrosion-proof contact, use a stainless rivet and silver solder.
    If the contact spring is toast, it may get a bit more complicated, but a lot of hardware stores have small spring ***ortments.
    Pist-n-Broke and loudbang like this.
  11. nochop
    nochop
    from norcal
    Try to find old stock or old sodiet, new repops ****
  12. shorrock
    shorrock
    Have a look at british motorcycles of the 70s. Norton Commandos have those sockets to light their tacho and rev counters, they should still be available
  13. Beanscoot
    Beanscoot
    Too bad there's not a "yuck" ****on:
    At least the wires aren't neon coloured.
  14. PhilA
    PhilA
    I bought a bag of br*** rivet eyelets for a dollar. Had about 100 in. Just soldered the wires into those, uncrimped they fit into the sockets just fine.
    Phil
  15. mcmopar
    mcmopar
    from Strum, wi
    Thanks for the input, I got it covered now, just had to look at it differently. I will buy new pigtails.
    Tony
    Tman and pprather like this.
