Car in a fire?
Discussion in 'The Hokey Ass Message Board' started by C. Montgomery, Apr 26, 2010.
  1. Toner283
    Toner283
    Anything can be saved if you want it bad enough. the El Matador is a prime example. that car was in a bad fire & was pretty much screwed. it sat outdoors for several years with nothing covering it & the roof caved in.
    The guys who fixed it did a spectacular job, you would not know it was in a fire if you were not told.
    If all you have is blistered paint you should be able to repair it or have it repaired pretty easy.
    Thanks to Rikster for the pics, I got them from his fotki album.
  2. vert1940
    vert1940
    this car burnt..was in a garage fire.all the paint was burnt off,a rafter came down on the panel between the decklid and the top,the gl*** was all burnt up,lead melted off,all the pot metal was in blobs...took it to the dipper and had it cleaned..no damage to the body from the heat..turned out pretty good.
  3. stillrunners
    stillrunners
    from dallas
    running and driving...and hell it's got a ***le?...who needs stinkin paint...
  4. havi
    havi
    '36 chevy 2 door w/artillery wheels been garaged for many years burned up a couple weeks ago just up the road from me. Sad sight.
  5. vert1940
    vert1940
  6. Da Tinman
    Da Tinman
    Yo need to quit showing that pic, its probably one of the most depressing things I've ever seen.:(
  7. temper_mental
    temper_mental
    from Texas
    The price would have to be very low for me to buy a burned 31 Murray 4 door!
    Also what is a slant windshield model A?
  8. abone1930
    abone1930
  9. 29nash
    29nash
    from colorado
    It's a no-brainer to me too.:D
  10. austinsailor
    austinsailor
    Back in the 60's I worked in a garage that used to also have a body shop. Before the body shop had closed they'd repainted a Falcon that had been in a garage fire similar to what you describe. They'd done a normal sanding and painting but after a little time the paint peeled. They had to sand it down again and repaint it. Several months later, after I was working there, it started peeling again. They brought it in again, this time another guy and I sanded it to bare metal, everywhere. They weren't taking any chances of a 3ed repainting. We sanded it entirely to bare metal, they started again. I never heard of it pealing after that.
    I suppose the lesson is, the old paint probably should all be removed, not just feathered out to look ok.
  11. bonez
    bonez
    from Slow lane
    Im w/ Hnstray on this.
    If its runnin and it has a ***le the only thing that should stop you would be the price if its too high!
  12. HotRod33
    HotRod33
    Wow... Denise when did this happen.....?
  13. impalabuilder
    impalabuilder
    from NJ
    http://science.howstuffworks.com/iron4.htm
    burning steel with paint, dust, etc. on it will not let paint adhere to it. All you have to do is remove all paint, sand and clean really well.
    as stated before, welding metal melts it, but paint sticks to that....only after it is sanded and cleaned really well.
    clearly an old wive's tale
  14. selohssa
    selohssa
    I did a repair on a 39 coupe that hit a moose. 6 months later, his shop burned down and completely burned the coupe. We redid that car in less than a year and in the 10 years since, I have not heard of any problems that he has had with it. BUY IT!
  15. C. Montgomery
    C. Montgomery
    Hit a moose then burned? Wow. Somebody has some really bad luck.
  16. hotrodladycrusr
    hotrodladycrusr
    In July 2000 to my completely perfect '47 Chevy convertible after getting smashed at the Grand Canyon then once home taken to a shop for repairs where the day after the car was repaired and freshly painted lighting hit the building and burned to the ground.
  17. hotrodladycrusr
    hotrodladycrusr
    and lots of us have experienced too much heat on a body panel when trying to weld it AND warped the **** outta the hood, fender, door, etc beyond repair. Not everything that has been heated is fixable. Ask me how I know. :rolleyes:
  18. Hnstray
    Hnstray
    from Quincy, IL
    Agreed.........but the reverse is also true.....that's all I'm saying. Another poster commented about depends somewhat on whether or not the car was doused with water while in the fire.........I agree with that too as being problematic. The real point is.........it all depends.......not all 'burners' are created equal.
    Sorry to hear you had such a string of misfortune with the Chevy Convert.....THAT is a really disappointing series of events.
    Ray
