Hot Rods Car is leaning
Discussion in 'The Hokey Ass Message Board' started by dapirate, Jul 4, 2015.
  1. dapirate
    dapirate
    from Alpharetta
    Guys this problem is kicking my ****.
    The drivers side is about half inch too high in the front and it makes for an obvious lean. I've isolated the issue to the front of the vehicle but I cant pinpoint it.
    I have split bones, a leaf spring in the front and 2 shocks. I also have one of those rare 60hp tubular axles.
    If I put the front on jack stands the car is level.
    Any ideas???
    Thanks
  2. Don's Hot Rods
    Don's Hot Rods
    from florida
    More info needed and probably pictures too. What type of spring(s). What you want to do is get an accurate measurement from floor to bottom of frame on all 4 corners. Pick the same reference spot. You want to make sure the problem is ABOVE the axle line.
    If nothing works, get a fat GF. :D
    Don
    lothiandon1940 likes this.
  3. woodiewagon46
    woodiewagon46
    from New York
    Some time it's the "U" bolts that hold the springs in the cross members. Both front and back can effect the "lean". Sometimes one of the "U" bolts are too tight or even stripped. I would loosen them and see if it changes the situation and then retighten them evenly.
    lothiandon1940 and Hnstray like this.
  4. drifters cc
    drifters cc
    Do you have a front or rear panhard bar?
  5. Don's Hot Rods
    Don's Hot Rods
    from florida
    Woodie is right, you can tighten and loosen the opposing nuts on the U bolts and increase or decrease the torque and change the leveling of the car.
    Don
  6. Jalopy Joker
    Jalopy Joker
    "gangster lean"
  7. dapirate
    dapirate
    from Alpharetta
    The rear p***enger side is 20.25" driver side is 20.75"
  8. millersgarage
    millersgarage
    are you sure it's issue is in the front? Many "front" issues are actually due to rear suspension being off. I smidge off in the rear can cause a big difference in the front. Measure everything, verify spring bushings are not worn, etc.
  9. dapirate
    dapirate
    from Alpharetta
    I thought about the U bolts, but if you look at the pic the space is so tight I can't get anything in there to unloosen either side.
  10. dapirate
    dapirate
    from Alpharetta
    Yes I have rear panhard bar
  11. pitman
    pitman
    Copper water pipe...makes good shim matl...
    L e v e l her out, above the top leaf.
    First though, the clamping force(s) can affect a minor lean
  12. Think about how the car sits on the spring, its basically balanced.
    Some extra weight on one side (such like a starter) is enough to tip it slightly.
    A driver, p***enger, or absence of one is engough to tip it slightly. This cause trouble most of the time because its going to either go down the road with a lean & park even or park with a lean and go down the road even.
    Extra tension on one side of the perch via u bolts is enough.
    A slightly angled spring perch is enough.
    Tight shackles because of short shoulders is enough.
    Worn spring bushings is enough.
    A leaf spring with slight rate variation side to side is enough.
    A small shim at the perch on the low side should set you straight in most cases.
    lothiandon1940 and pitman like this.
  13. Todd M.
    Todd M.
    The first thing I would do is look at all the shackles. Sometimes they can be to tight and bind on one side causing the lean, especially if it has been jacked up and not had a chance to level out. Hope this helps.
  14. Hot Rods Ta Hell
    Hot Rods Ta Hell
    Your driver side spring perch is canted and leaf spring is torqued. Are the perches floating (spin) or bolted/welded solid? Also, the perch mounts look to be welded on at different heights on the wishbones-though this may be an optical.
    Spring could be twisted/ out of balance. Try removing the spring for a visual then reinstall; flipping it side to side.
    Axle may be bent. Have you had the car aligned? (How's the camber, tire wear, steering, etc?)
    You said it straightens out when on jackstands. Try placing it on 4 jackstands to bring the rear suspension into the game.
    Brake lines scare me. For some reason they look too short as they're almost out of slack with the tires turned straight....
  15. Todd M.
    Todd M.
    Do you pics of the rear end shackles?
  16. wbrw32
    wbrw32
    Have you thought about maybe a sifference in those big old tires??? change them from side to side and see the difference
    changes to other side.....
  17. pitman
    pitman
    Just noticed the angle of the front shackles! The main leaf appears short, or if a 45* shackle angle could be achieved?
  18. dapirate
    dapirate
    from Alpharetta
    I have coil overs on the rear
  19. dapirate
    dapirate
    from Alpharetta
    I've never rotated the rear tires, that maybe worth a shot
  20. dapirate
    dapirate
    from Alpharetta
    tire wear looks fine, steering feels fine
  21. Don's Hot Rods
    Don's Hot Rods
    from florida
    Crank on one of the coil over adjusters to see if it changes the lean.
    Don
  22. drifters cc
    drifters cc
    I've been doing a lot of ch***is fab and I'll share this. My car has been sitting dead level ( on front and rear transverse springs) for 2 months with out a panhard bar. I just installed my ( rear only) panhard bar and when i stepped back to look at the ch***is the whole rig was listing heavily. I adjusted the bar length to re level the ch***is. I figure I will have to do that again once the (body) weight is compressing the suspension to its final weight and ride height. Adding weight or changing suspension heights can cause your car to lean.
  23. dapirate
    dapirate
    from Alpharetta
    If I raise the coil over it adjust the lean. I removed the panhard bar and the car sat lower but the lean was still the same
  24. wbrw32
    wbrw32
    "LOOKS" can be decieving....Change the fronts from side to side...dont be so lazy.
  25. dapirate
    dapirate
    from Alpharetta
    Swapped the rear tires no change. I'll try the front
  26. The Pan hard bar should not have a weight load on it.
  27. 2X, your panhard bar is in a bind.....
    To find out your leaning problem you will need to check the weight at each corner. Use a scale determine if one corner is heavy or light. If you want your coilovers to be 'even" then you will have to change your spring rate or shim the spring. I would just adjust the spring to make the car even and be done.
