car shuts off at operating temp
Discussion in 'The Hokey Ass Message Board' started by 55oldsrocket, Jun 21, 2010.
  1. moparjack44
    moparjack44
    I am using MSD box, but if I read these instructions correctly, the ballast resitor goes between the + coil side and the ignition switch.
    I found pictures and instructions on Mallory site (generic instructions for any brand).
    Jack
  2. Lobucrod
    Lobucrod
    Alliance Vendor
    from Texas
    That Accel coil does not require a balast resister. I'm running one on my nail head with my home built HEI conversion.
  3. 55oldsrocket
    55oldsrocket
    from Santa Ana
    thank you .ill keep you posted
  4. 1956 F100
    1956 F100
    from Louisiana
    When it stops running check to see ig you have fire at the plug . If it does then chances are its not the ognition.
  5. imnezrider
    imnezrider
    Since it seems you haven't done the basic "spark test", I'm betting on the coil also. As for vapor lock, I've seen it all during the past 50+ years and no one has ever proved to me their is such a thing. I've seen clothes pins on fuel lines, aluminum foil wrapped around fuel lines and water poured on water pumps, but obviously, none of these things get to the heart of the problem. For instance, if your fuel pump isn't producing enough pressure and/or VOLUME, many would diagnose this as "vapor lock". Symptoms are definitely the same when it comes to a bad coil...heat DOES affect things, but it's still a bad coil that's causing the problem.
    You've eliminated the vapor lock theory.......
    Be sure to post back...we're all interested.
  6. tommy
    tommy
    I agree. I think vapor lock is a myth. I did the tin foil clothes pin tricks too and it didn't help then and that was 40 years ago. It still gets repeated over and over again.
  7. imnezrider
    imnezrider
    I hear that. :)
  8. I'm thinking that the ignition module is going bad.
  9. imnezrider
    imnezrider
    Shovel...that's a good point and it's easy enough to check out before throwing dollars at a coil that he may not need and also may not be able to return. Some parts suppliers get pretty hard headed on electrical items. Like someone mentioned, put the points back in and try it first.
  10. 55oldsrocket
    55oldsrocket
    from Santa Ana
    alright, went out to the shop. i let the car heat up and shut down, took off #1 and ground the plug and i got no spark. went to the parts store
    imnezrider - the parts store exchanged the new coil, as it had warranty, they wanted to test it but the coil was to hot to even hold, so they said "just take the new one" .
    went back and threw the new coil back on, let it idle, pop , pop pop and.......shut down again.
    i sprayed a little starting fluid on carb and still a no go.
    I guess the next thing would be to replace the module. hmmm??
  11. claymore
    claymore
    Apparently neither of you have owned a Super Cobrajet Torino running open headers on a 100 degree day at the dragstrip. The FE under stress puts out so much heat in that tiny enclosed space vapor lock is a constant and "Real" problem.
    But of course the problem was solved by running the fuel line through a "cool can" full of ice and no other changes NOT by the myth of putting clothespins on it.
  12. gofaster
    gofaster
    from georgia
    I second the coil.
  13. tjet
    tjet
    Electronic modules can be sensitive to heat. Sometimes they fail completely, and other times they work ok after they cool off. I've seen this many times on HEI's - on either the module or pickup.
    Usually when a coil fails, it doesn't come back to life
  14. After it shuts off, pop the cap and spray the module with contact cleaner to cool it off. Then throw the cap back on and try it.
  15. tommy
    tommy
    Apples and oranges. I'm talking about box stock street driven cars that performed well for years and as soon as they won't start in warm weather it's vapor lock.
  16. imnezrider
    imnezrider
    Maybe you should put points back in and try it...seems like you've narrowed things down now.
  17. Fuzzy Knight
    Fuzzy Knight
    from Santee, Ca
    Is the coil wired correctly?
  18. moparjack44
    moparjack44
    You can test the module to see if good. Will need a voltmeter.
    Again, go to the Mallory web site for pictures and instructions to test the module.
    Jack
