Technical Car stalls at traffic light
Discussion in 'The Hokey Ass Message Board' started by joseangel_1976, May 3, 2019.
  1. joseangel_1976
    joseangel_1976
    I got a 62 cadillac I've been driving for work almost every day while my daily driver gets fixed. She's running smooth, got a fan shroud for her, new spark plugs, she runs great when cold except if i'm in traffic for too long for almost 30-40 mins once i hit a stop light my car stalls. I have not yet replaced the spark plug wires, but other than that I'm wondering why my car would stall. Note my car has an edelbrock 1406 carb.
  2. Does it start right back up?
  3. ClayMart
    ClayMart
    Does the carb have a working choke? Is it adjusted properly? After 5 or 10 minutes of driving from a cold start the choke valve should be fully open. If it isn't it may be running too rich and flooding out at idle.
    Make sure the air cleaner or any other linkages or vacuum hoses or fuel lines aren't interfering with the throttle or choke linkages. Look for split or leaking vacuum hoses while you're poking around in there.
  4. wheeltramp brian
    wheeltramp brian
    Edelbrock flooding/ boiling over from heat.insulator? regulator?
    Johnny Gee and F&J like this.
  5. Bandit Billy
    Bandit Billy
    Stick a phenolic heat shield under the carb.
  6. 302GMC
    302GMC
    from Idaho
    Perhaps the idle speed screw could be the problem .... or those mixture screws sticking out the front ?
  7. joseangel_1976
    joseangel_1976
    Yea it starts right back up. I usually put it in neutral
  8. joseangel_1976
    joseangel_1976
    Where is the choke valve? I'll have to see if it's open. I do notice my muffler leaves a black spot on the ground wonder if it is running too rich
  9. joseangel_1976
    joseangel_1976
    Well I just installed a fan shroud and thermostat at 160 degrees so the car is pretty cool almost at 1/4 on the temp gage. The hood is missing the heat insulation tho :(
  10. joseangel_1976
    joseangel_1976
    Where can I get one?
  11. joseangel_1976
    joseangel_1976
    That's what I was wondering. I mean it does idle perfect but once it's warmed up I notice it stalls if u stop really fast
  12. ClayMart
    ClayMart
    It's the flap or door in the bowl cover above the primary throttle bores only. Sometimes called a "****erfly". It's shown here in the closed, cold start position. The valve should open vertically as the engine warms up.
  13. joseangel_1976
    joseangel_1976
    Oh ok I'm gonna check it tomorrow and keep u posted. I appreciate the pic
  14. morac41
    morac41
    It probally needs a 1" rizer under the carb base if it not the choke sticking
  15. ClayMart
    ClayMart
    If it's too rich at idle, the choke adjustment is just one possible culprit. Could be a sunk or mis-adjusted float, excessive fuel pressure, trash in the needle and seat, etc. Next time you have it idling with the hood open, remove the air cleaner and fully open the choke valve. Look down into the primary throttle bores and see if you notice liquid fuel dripping off the main nozzles or out of the vent tubes.
    Are you running the stock mechanical fuel pump or have you added an electric fuel pump by chance?
  16. joseangel_1976
    joseangel_1976
    I still use the manual fuel pump
  17. Flathead Dave
    Flathead Dave
    from So. Cal.
    It's supposed to stop at lights.
