car wont start
Discussion in 'The Hokey Ass Message Board' started by corvair63, Jan 14, 2013.
  1. corvair63
    corvair63
    from denver
    so my falcon will not start unless it is pushed and i pop the clutch ill try starting it with the key for about five mins wont do anything it has spark has gas and nothing but the first time i pop the clutch it fires right up
  2. tb33anda3rd
    tb33anda3rd
    how does the spark look? will it jump 3/8" with a good snap?
  3. harley jim
    harley jim
    I have had this problem also. found it to be most often caused by low voltage. will it start with the key if you put a battery charger on it? I had a farm tractor that the starter insulated itself from the block had 5 volts of voltage drop from the block to the starter case.
  4. corvair63
    corvair63
    from denver
    nope i just had my battery on the charger for awhile and still did the same thing
  5. davey
    davey
    Check the balist resister.
  6. VoodooTwin
    VoodooTwin
    from Noo Yawk
    Did you recently change the wiring? Do you have a solid/clean ground between the starter/engine block and battery?
  7. kevin47
    kevin47
    I wouldn't worry 'bout low voltage...Even with a six volt system...I've found that a dry carburetor accel-pump leather/issues won't let me start a lot of vehicles without priming, first....Will it start by key, after it's warm...?
  8. BORRACHO13
    BORRACHO13
    from Menifee CA
    I am guessing it cranks with key but no start? if so does it sound like a weak crank?
    where is the battery located? all grounds to block good?
  9. tb33anda3rd
    tb33anda3rd
    i would bet the starter is drawing too much amperage, do to bad connection, grounds, or wear and that the spark is very weak when the starter is working. there must have been a cranking issue for you to have tried to pop start it.
  10. Fenders
    Fenders
    Probably low battery.
    Put jumpers on from a known good running vehicle. If it starts then, it's your battery -- bad or not getting charge.
  11. sunbeam
    sunbeam
    Check the selonid I terminal to see if it's got voltage when cranking.
  12. George/Maine
    George/Maine
    Those falcons came with hand cranks did,nt they.
    There should be a wire from selinode 2 post ,
    I terminal goes to IGN coil pos terminal.
    Gives more voltage when starting.
  13. Is the starter cranking over for the entire 5 minutes? :confused:
    Is the starter cranking at all?
  14. desotot
    desotot
    Does the ignition byp*** wire on the starter solenoid have a good connection or could that wire be broken or not be hooked on to the coil?
  15. corvair63
    corvair63
    from denver
    oh no i didnt crank for five minutes all at once and i think i found the problem after i got it started there was a major vacuum leak i fixed that and it fired right up
  16. BORRACHO13
    BORRACHO13
    from Menifee CA
    :cool:
    Sounds good...
  17. pdunn10
    pdunn10
  18. kevin47
    kevin47
    low voltage....Geez...
