Technical Car Y-block VS Truck Y-block
Discussion in 'Traditional Hot Rods' started by 1955 F-100 guy, Jul 7, 2017.
  1. 1953-55 F-100 guy
    1953-55 F-100 guy
    from NE Pa
    Is there a difference and what is it -- can my F-100 TRUCK 272 Y- block engine be installed into a 1957 Ford car-- Thanks
  2. Hollow Head
    Hollow Head
    from Finland
    Some truck engines have huge sodium filled exhaust valves with large diameter stems. Otherwise no big difference exept compression ratios may vary depending about heads.
    www.ford-y-block.com may help...
  3. Hollow Head
    Hollow Head
    from Finland
    Ah, forgot to mention different oil pans and dip stick location differences and front mount to frame...
  4. same on cars and truck up to 1ton for the most part
    trucks sometimes have different oil pans
    the bigger HD trucks got the different heads with sodium filled valves to handle the extra heat, governors and some had different exhaust manifolds
    a lot of the truck heads had smaller valves than the car heads
  5. sunbeam
    sunbeam
    Some large HD truck 292s had steel cranks and heaver rods
    OahuEli, dana barlow and stillrunners like this.
  6. stillrunners
    stillrunners
    from dallas
    yep....Ford trucks carried them to 1964....had one with Y block and a 4sp granny.....worked it good......
  7. dana barlow
    dana barlow
    from Miami Fla.
    There is a Y truck water pump that has a high fan mount as part of it=that water pump dose not fit in car,take it off,car water pump just bolts up. The timing chain cover for front mounts have longer lower for side bolts/but dosen't matter/can be used with side mounts anyway.
  8. Vimtage Iron
    Vimtage Iron
    That water pump with the high mount fan is really hard to get, I searched all over for one and had mine rebuilt.
  9. jimmy six
    jimmy six
    Thermostat housing. Truck is vertical, car 45* to the right.
    dana barlow likes this.
