Carb ? 215 buick aluminum v8
Discussion in 'The Hokey Ass Message Board' started by Javier, Oct 11, 2009.
  1. Javier
    Javier
    1. Strugglers C.C.
    will a edelbrock 600 cfm 4 barrel carb fit on a stock 215 v8 buick 4 barrel intake.?
  2. wickedgoodracer
    wickedgoodracer
    thats a lot of carb for 215 cubes,rodchester 4gc is the way to go
    is the motor stock?
  3. wickedgoodracer
    wickedgoodracer
    with a adapter, would be the answer to the original question
  4. Unless you have it really hopped up look for something around 400cfm. If you are into the unusual, look on some of the english stuff (Rover, etc.) because they bought the design and use it in several English makes. I have an acquaintance who drives a MGBGT V8 that is the same engine you have.
  5. 390 cfm Holley is the accepted carb for these engines.
  6. J Man
    J Man
    from Angola, IN
    the 390 cfm is the way to go as mentioned before.
  7. Javier
    Javier
    1. Strugglers C.C.
    thanks guys.Ill pass it along to my buddie with the Buick
  8. fab32
    fab32
    Like others have posted that carb is a bit too much for that engine. Don't kill a great little powerplant by drowning it and killing the bottom end power.
    Frank
  9. carbking
    carbking
    Buick originally used both a two barrel (the 2-GC) or a four barrel (the 4-GC) Rochester carburetor on the 215.
    The Oldsmobile version could be had with a large 1 barrel and a turbocharger (the Jetfire option).
    Pontiac also had their version.
    There was also an aftermarket dual 2 barrel intake available.
    The original Rochester, while pricey, is an excellent choice.
    Jon.
  10. captain scarlet
    captain scarlet
    from Detroit
    The favorite carb and intake for the Rover/Buick 215cui is the Edelbrock 390 (expensive but the best) and the Offenhauser intake.
    I had a 600 Holley on a 215 and it drowned it. Fitted the 390 Holley and it ran like a champ:D
  11. JSBriggs
    JSBriggs
    from Auburn, CA
    Or there is always dual side drafts.
    -Jeff
  12. Javier
    Javier
    1. Strugglers C.C.
    Thanks guys. I guess the 390 is the one he'll use
  13. I have a olds 215 with offenhauser 4bbl intake in my 75 Lotus Elite with a 625 cfm Carter carb. Way too much. I am now shopping for that Holley 390. Good luck man.
  14. carbking
    carbking
    Another option is the Carter AFB of 400 CFM. Part numbers either 9400s or 9410s.
    Jon
  15. Gromit
    Gromit
    Funny enough... I have one with that set up. 1981 Rover 3500 with performance intake and exhaust. Just put an edelbrock Performer on it. yeah... lot of carb for the motor, but it's what we had. Need to take it down a few steps I think. Car came with a big Holley double-pumper. At least we are headed the right way.
    So.. anyone wanna buy it?
