Customs Carb air fuel mixture
Discussion in 'The Hokey Ass Message Board' started by moparjack44, Aug 18, 2026.
  1. moparjack44
    moparjack44
    Need to set fuel mixture screws, duel 500cfm Edelbrocks.
  2. squirrel
    Try it with them all out 1.5 turns from lightly bottomed, see how it works. If it blubbers, turn them all in an equal amount until it stops. If it coughs, turn them all out an equal amount, until it stops.
    Play with it, see how it does. If you get some specific issue, tell us about it, maybe we can help.
    The point is to make sure they're all the same number of turns out from lightly bottomed out. That means, tighten them so they just seat the screw, don't apply any torque to them. Then unscrew them (counterclockwise) the same number of turns, aiming for between 1 to 3 turns out.
    And do all this adjusting after it's warmed up.
  3. moparjack44
    moparjack44
    Fouling plugs had badly
    1st Gen 392 Hemi, electronic ignition, no MSD box. It caused more issues, than it was worth.
  4. jimmy six
    jimmy six
    Check to see if the metering rods are being ****ed down at idle. If your care full you can do one at a time.
  5. moparjack44
    moparjack44
  6. moparjack44
    moparjack44
    I know it is caused because it is running too rich. Very difficult adjusting rear carb.
    I know needs to be lean.
    I was considering adjust back carb to lean (in), then do fine adjusting on front carb only???
  7. squirrel
    You could try that. But if they all need to be out less than half a turn, then something else is wrong.
    Did you set the float levels correctly?
    The chokes are both fully open?
    jimmy six and ClayMart like this.
  8. jaracer
    jaracer
    With it warm and idling, look down the throat of each carb to see if any fuel is dripping out the venturi's. You should see no fuel, the carb throat should be dry. If you do see fuel, it either means the fuel level is too high, needle and seat is leaking, or the throttle plates are opened too far causing the fuel to be pulled from the venturi's.
  9. anothercarguy
    anothercarguy
    And/or the fuel pressure being delivered to the carbs is too high.
    61Cruiser and jaracer like this.
  10. lostone
    lostone
    from kansas
    First off are you running them 1 to 1 or progressive ?
    Which model edelbrocks are you running ?
    Loosen the screws on the 2 little top caps and rotate the caps just enough to see the metering rods without them being able to come out. Start the car and watch the metering rods, blip the throttle, they should rise and immediately go back down when the vacuum comes back.
    You might have to go to a softer spring in the metering rods...
    Rodney Dangercar likes this.
  11. swade41
    swade41
    from Buffalo,NY
    Put a vacuum gauge on it and adjust for highest vacuum reading, do front carb then back carb, then repeat process again.
    On dual carbs repeating the process is important because one carb will effect the other.
    After you've done it with the guage a hundred times then you can do it without the guage using your ear to listen for highest rpm and your hand to feel for the smoothness of the engine.
    Just Gary likes this.
  12. ClayMart
    ClayMart
    Keep in mind that the screws you're adjusting will only affect the idle mixture. They will have little or no effect on the rest of the fuel curve.
  13. moparjack44
    moparjack44
    Thanks everyone.
    I am going to try reagjusting using my va***n gauge, to get as lean as possible with the highest va***n.
  14. moparjack44
    moparjack44
    Yes. Thanks.
  15. squirrel
    I haven't used a vacuum gauge to adjust idle mixtures for decades, and I've put hundreds of thousands of miles on carb equipped vehicles in that time. But don't listen to me :)
  16. 19Eddy30
    19Eddy30
    from VA
    Your initial timing BTC ,
    Also not sure on Edelbrock
    above into the Transfer slot , does it apply ?
  17. patsurf
    patsurf
    :):p:D
  18. saltflats
    saltflats
    from Missouri
    Edelbrock carburetors should have a small vacuum port on the front drivers side. When at idle with a vacuum gauge on that port you should read no vacuum. That is ported vacuum and when you read vacuum at that port you are no longer getting proper idle mixture adjustments.
    If you are reading vacuum at that port that means the throttle plates are open to much.
    Tickety Boo and Just Gary like this.
  19. kabinenroller
    kabinenroller
    2x500’s equal a lot of CFM, hopefully you have an engine that will digest that amount of air/fuel. I am running two Holley 390’s progressively which is just right for the engine size I have. It still took quite a bit of adjustment and tuning to make them right. I use an air/ fuel gauge
    to monitor the ratio.
