Carb backfire?
Discussion in 'The Hokey Ass Message Board' started by solo_909, Aug 12, 2012.
  1. solo_909
    solo_909
    Update, I took my car in for a full tune up and everything look good to go. It hasn't backfired since that day so it must have been condensation from the car wash when I sprayed down the motor.
  2. ZACH2211
    ZACH2211
    from Minnesota
    I belive i am having a simular problem with my motor. The thing will rev perfectly under gradual or even quick acceleration. If I slam the pedal to the floor though it will blow out the carb once then get up and go. I found the vac advance diaphragm was not holding so I replaced it and have been through and through the ign system to ensure everything is correct. I have 3 holes on my linkage to adust the pump throw and none seem to make a diff. It seemed to be spraying ok when the carb was apart, but I can't help but think some how its to blame.
