Technical Carb Block off
Discussion in 'Traditional Hot Rods' started by ‘28 RPU, Feb 22, 2024.
  1. ‘28 RPU
    ‘28 RPU
    I am in the development stage of a “B” Motor build for my ‘28 RPU. I’m going to be installing a Riley twin downdraft manifold but for the short term I want to block the rear one off. I saw that somebody had one for sale the other but I can’t remember who. I know that in a pinch I could make one but I would prefer to just buy one. Anybody know where I should go for this?
  2. Moriarity
    Moriarity
    SUPER MODERATOR
  3. 05snopro440
    05snopro440
    Is there any chance you could end up with some lean cylinders doing this?
    Budget36 likes this.
  4. Kevin Pharis
    Kevin Pharis
    from Califunny
    The Riley is basically a plenum style intake with the carbs very close together. I made one very similar for my T (using Winfields) and am currently running on 1 carb with no noticeable spark plug color difference between front and rear cylinders. 2 carbs did run a bit stronger… but…
    sdluck, Deuces, cederholm and 2 others like this.
  5. cederholm
    cederholm
    That motor is beautiful!
  6. 5280A2
    5280A2
    Check with Charlie Yapp at Secrets of Speed. His Scalded Dog banger speed parts include an "Equalizer" dual manifold that is supposed to work with either one or both carbs. He will readily share info if you call, text or e-mail. Contact info is on Secrets web page.
  7. ‘28 RPU
    ‘28 RPU
    Equalizer is out of production (unfortunately) or I would have bought one
  8. jimmy six
    jimmy six
    Many duel quad systems run Progressive on the rear carb from the factory. Personally I’ve run mine 7 years and never see a lean condition running or on the spark plugs; the system described should not have a problem.
