carb choices for 2x1 intake
Discussion in 'The Hokey Ass Message Board' started by cncd11, Jun 19, 2012.
  1. cncd11
    cncd11
    got a 50 chevy that i am doing a 235 engine swap. The engine i am currently rebuilding is out of a 58 chevy Biscayne... new valves, valve job, hardened valve seats, mild port job to smooth everything out, gonna run the patricks e-2 grind rumpy cam compression will be raised depending how much the block needs decked along with the head. Question is which carbs should i use? Langdons sells the 2 carters but not sure if they will flow sufficient air plus i am not a fan of that huge electric choke on the side. I would like to run a couple 2 barrels but not sure i need to. Let me know what you guys suggest.
  2. cncd11
    cncd11
    lots of views but no responses. any light on this subject?
  3. chaddilac
    chaddilac
    two stock 50 chevy carbs, or the truck carbs.
  4. carbking
    carbking
  5. Flop
    Flop
    stromberg bxov2 carbs .
  6. dtwbcs
    dtwbcs
    from Brenham,TX
    Call&talk with Tom Langdon about his setup.He knows his stuff
