Technical Carb cleaning
Discussion in 'The Hokey Ass Message Board' started by upspirate, Mar 4, 2021.
  1. upspirate
    upspirate
  2. birdman1
    birdman1
    It doesn't come up
  3. Bob Lowry
    Bob Lowry
    Seems to be working now.....
  4. Beanscoot
    Beanscoot
    Very good article, almost scholarly.
  5. Truck64
    Truck64
    from Ioway
    They mention methylene chloride. That used to be the "good stuff", if toxic. It was also included in paint strippers. Makes sense, since old gasoline turns into gum and varnish. But it's been banned from paint strippers as well. Article says it's still available but they don't say where.
    blowby likes this.
  6. Beanscoot
    Beanscoot
    In my area methylene chloride is available at the local plastics store, but expensive.
    I don't know if it still is in paint stripper in Canada.
  7. Truck64
    Truck64
    from Ioway
    "Local plastic store".
    (What the hell is that?) What is it used for?
    VANDENPLAS likes this.
  8. Atwater Mike
    Atwater Mike
    A type of methylene chloride is used in plastics for bonding purposes, it was available in small bottles (gl***) as a cement for plastic model cars, aircraft, etc.
    We have a large plastics & metal distributor in Turlock, CA.
    Just google 'plastics' in your area, dealers are numerous.
  9. Beanscoot
    Beanscoot
    It's called "Industrial Plastics and Paint" and they sell sheets of plastic, rods, glues, solvents etc. etc.
    A neat place, I ***umed other large cities would have such stores.
    VANDENPLAS and Truck64 like this.
  10. wvenfield
    wvenfield
    I've been cleaning carbs with a cheap Harbor Freight ultrasonic and simple green and have had great results. It may take some time with really gunked carbs but while I do not clean a lot of them (I am not in this business) I've not had one not come clean.
  11. upspirate
    upspirate
    This is the reason I found the article, I was searching for what to use and the ratio.
    I bought one just like the H-F one off Amazon, but sent it back and bought a more industrial stainless steel one for actually less money.
    Most of the carbs I will be cleaning are outboard 2 stroke carbs anyway
  12. Beanscoot
    Beanscoot
    Ultrasonic sounds like a great idea, if a guy has access to one.
  13. 30tudor
    30tudor
    I redid these a couple of years ago. Had them all vapor blasted while they were apart.
  14. upspirate
    upspirate
    Looks great.
    Does the vapor blasting just do the outside though? Or does it clean the p***ages?
    I need to get all the small internal p***ages...I believe the ultrasonic will clean those
  15. wvenfield
    wvenfield
    I don't generally promote Harbor Freight stuff but you can buy one for $90. Mine was less than that when I bought it 7-8 years ago. It's still working. They also have their coupons you can use that make it even less.
    You have to take the carb apart to get it to fit. Small carbs like a motorcycle carb will fit without taking it apart but you want to take it apart anyway. For some larger carbs you have to do one side and flip it over to get the entire carb.
    I had an ATV carb I needed cleaned. The local shop charged $60. Like I said, I do not do this for a living so I clean a few a year. I use simple green straight. If you are a shop you likely want a commercial one but for your own use it works just fine. You then have it around to clean anything that will fit.
    Did these recently.
  16. Frankie47
    Frankie47
    from omaha ne.
    In the Navy we used MEK and Naptha Alphatic to clean parts and there was a liquid freon for hyd samples.........no gloves worn....lol, except when we used baby ****/paint stripper.
    vtx1800 likes this.
  17. lake_harley
    lake_harley
    ^^^^^ X2 on MEK, but it's pretty nasty stuff.
    Lynn
    Frankie47 likes this.
  18. atch
    atch
    We know this stuff as Methyl Ethyl Keytone, but the industrial hygienist at the hospital I worked at called it Methyl Ethyl Death.
    Frankie47 and lake_harley like this.
  19. Glenn Thoreson
    Glenn Thoreson
    from SW Wyoming
    What ever happened to the good old carb cleaner that smelled like creosote and would remove anything that wasn't metal, including your skin? A 5 gallon bucket of that stuff would last forever. I seem to remember Harbor Freight (?) having something similar. Not as potent, though. A neighbor bought a can of this to clean his carb but it took lots of soaking and some hand work. Small bucket, too. All the good stuff has been banned now. I have a squirt can of rubber cleaner that has meth choride in it. I use it sparingly and guard it with my life as it's probably too hazardous now. Used to be a very popular solvent.
  20. AngleDrive
    AngleDrive
    from Florida
    ^^^^EPA banned it cause it kills you.
  21. Frankie47
    Frankie47
    from omaha ne.
    Even Berrymans ain’t as strong as it used be!
  22. Truck64
    Truck64
    from Ioway
    Well it is dangerous if mishandled. So is water, get right down to it. They slipped over the line into silliness a long time ago.
    What happens, one person ****s their pants, so then we all gotta wear diapers. At minimum put up with a wall of text and warnings on everything.
    "DO NOT INGEST CONTENTS OF BATTERY"
    warhorseracing and lake_harley like this.
  23. 1952henry
    1952henry
    Unfortunately, common sense is not a flower that grows in every garden. Bring up lye (not for carbs, they don't get along), and boy do the people bark about how dangerous that is. Thousands of pioneer women must have have been horribly disfigured or killed making soap. Not to mention all the Scandinavians preparing lutefisk.
    warhorseracing, Truck64 and 30tudor like this.
  24. Beanscoot
    Beanscoot
    A lot of people hurt their brains huffing gas.
    warhorseracing likes this.
  25. vtx1800
    vtx1800
    I worked aerospace in the late 60's testing materials that went into the space craft for flammability after one burned on the pad. When I started most of the products we tested burned very well, and left a nasty mess in the test chamber. We used MEK and freon as well as 409 and anything else we could to clean the test chamber (they were aluminum, two or three feet deep and a couple of feet in diameter. I can't remember if we used rubber gloves, but I doubt it. In the same lab we had a chemist type guy that pulled samples off of the material to test for carbon monoxide/total organics and one day doing a base line he found cyanide in the air:( I'd still use MEK but I'd want to use it in a vented environment. It was good stuff.
  26. atch
    atch
    Truck64, warhorseracing and Beanscoot like this.
  27. deathrowdave
    deathrowdave
    from NKy
    1 1/2 gallon of distilled water , 20oz of Muriatic Acid , rinse 3x in hot water , soda blast and its as best as anything I have eve4 used to date . I also use an old crock pot and Simple Green . I never use wires to clean p***ages , I think the score the bores of p***ages and change flow as it was designed . Just my 2 cents also . No matter what you use , use the PPE , gloves and safety gl***es on first , please .
    Truck64 likes this.
