Carb help please
Discussion in 'The Hokey Ass Message Board' started by DarkVudu, May 30, 2007.
  1. DarkVudu
    DarkVudu
    from Denton,Tx
    Hey guys i gotta 51 ford f1 with a bad carb. I've been to all the auto part stores and no one can get me a new one. I don't know where else to look. Can anyone point me in the right direction?
    Thanx guys ;)
  2. squirrel
    what's wrong with the one you have? usually they can be fixed....did you try?
  3. DarkVudu
    DarkVudu
    from Denton,Tx
    Well I bought a kit for it but as soon as i unscrewed the top it fell apart due to the case being cracked:(
  4. DarkVudu
    DarkVudu
    from Denton,Tx
  5. HotRodFreak
    HotRodFreak
    There are many out there to buy if you need to be original.
    Another option is to buy the adapter from early Ford 3-bolt base carb to a more modern 4-bolt base carb.
  6. DarkVudu
    DarkVudu
    from Denton,Tx
    Ya i'm really tryn to stick to stock as much as possible
  7. squirrel
    look around for a used one as a parts donor for yours.
  8. Al Von
    Al Von
    I'm bumping this because i'm in the same predicament. I have a '51 shoebox with the flat 6. The carb all but dissolved after an overnight soak in carb cleaner. I have a Holley 1920 from a slant six but it has too big of a footprint for the intake. Will a 94 fit in place of this little two-bolt, one-barrel? I dont need to be original, just use something that will fit!
    Thanks for any help!
  9. alchemy
    alchemy
    www.macsautoparts.com
    Or contact any of the vendors listed in the HAMB-O-Dex that rebuild old Ford carbs.
  10. DarkVudu
    DarkVudu
    from Denton,Tx
    Awesome man thanks for the help!:D
  11. Al Von
    Al Von
    Thanks, I found just what I needed!
