Carb help please
Discussion in 'The Hokey Ass Message Board' started by TopHat, Jun 30, 2010.
  1. TopHat
    TopHat
    from NC
    I have an old zenith updraft carb that I have to save.
    <center>
    As you can see the float bows is severely pitted, all the way through in some spots. Any ideas on how to save this? I was thinking about trying that 2 part gas tank putty. I did pull this off a running engine (that has to run again soon) The holes were "plugged" with what looked like red clay mud. BTW this is off a 1950 something Hough front end loader. I have no idea what the engine is, other then 4cyl OHV.
    Thanks for any help. I figured someone here would know how to save it.
    TopHat
    </center>
  2. Maybe you can try and braze it or fill it with lead.
  3. merf
    merf
    from new joisey
    Call Treadwell Carburetor in Treadwell N.Y. He may have a bowl or even an NOS carb.
  4. Commish
    Commish
    from NW Ok
    If that were mine, I would use JB Weld, it is a 2 part epoxy and gasoline does not seem to bother it.
  5. LUMBERJACK 50
    LUMBERJACK 50
    from upland ca.
    i second the JB weld.... it works well.
  6. carbking
    carbking
    What is the tag number of the carburetor?
    Jon
  7. TopHat
    TopHat
    from NC
    Thanks for the suggestions. I have not had good luck with JB weld and gas though.
    Carbking : No tags on the carb. Very little info on the machine at all.
    TopHat
  8. 1952henry
    1952henry
    If you have some old IHC four cylinder tractors around H or W4 (I'm not sure at the moment if they used Zenith carbs), see if they have a similiar carb. Hough was sold to IHC some time in the early 50s, they may have used the same engine.
  9. carbking
    carbking
    The tag is round, approximately the size of a dime, and is riveted to the body of the carburetor. There should be 2 numbers going around in a circle. The outer number would be the Hough number; the inner number the Zenith number.
    JB weld will get soft in approximately 3 months if used as a bowl repair in the bottom of the bowl; and fail shortly after that. If the casting is cast iron, is may be possible to braize in repairs, or silver solder.
    Jon.
  10. i have brazed several
    go to welding supply shop and ask what rod would be good with that casting
  11. jimvette59
    jimvette59
    Look at a DEVCON Product. This product has been around almost as long as that carb. You cant loose. Good luck.
  12. This might be a long shot, but if you know anyone at Kinsler the fuel injection guys, they have a green epoxy that used to be used on the old style injection setups that is impervious to about anything and will last pretty much longer than you or I. I have seen a set of race heads we used that epoxy on 20 or so years ago, these heads are still performing perfectly. We have used the epoxy on heads, intakes and yes carbs.
  13. Commish
    Commish
    from NW Ok
    Carbking, never had that experience with JB Weld, longest running test I ever had was a hole dead in the bottom of a gas tank. I drove that one for another 7 yrs with not ever a drip, and last I knew it was still holding. Maybe they have changed the product, that has been a while back.
