Technical Carb help.
Discussion in 'Traditional Hot Rods' started by Shoovel, Mar 1, 2023.
  1. Shoovel
    Shoovel
    So, I found out the carbs on my Blown Flathead Hot Rod are Holly 94s model 2110 “Bug Spray”. They have 1.5” throttle bore. Well, I ordered kits and new throttle shafts thinking they were the run of the mill Holly 94s. I was going to replace the throttle shafts due to wear, but the new shafts are for 1.250” throttle bore. Unfortunately I didn’t find this out till I had the one shaft removed.
    Anyone know where I might be able to locate a throttle shaft? If I can not find a new one, I may have to try to use the old one, but I kinda f’ed up the shaft by drilling out the screws.
    I sent an email to Vintage Speed and spoke to a fella at Daytona Parts.
    Thanks
  2. Tow Truck Tom likes this.
  3. Try Charlie Schwedler, he is the go to person for Holley / Ford two barrel carburetors. 715-662-9159.
  4. Shoovel
    Shoovel
    Thanks. All the “Bug Spray” carbs on the VWs appear to have a 4 bolt base. My bases are the 3 bolt style. Number on the carb body is LIST 3903 S.
  5. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    Charlies # 716 662 9159
  6. robert graves
    robert graves
    Charlie Price at vintage speed has them
  7. You are correct, the VW carb base is 4 bolt.
