So I have a edelbrock 650 avs carb. It's on a 350 mild cam. Problem seems to be too rich. When I mash the throttle it sputters real bad and wants to die. Also when cruising if I step on it, it kicks down a gear and does the same thing. However if I stay on the gas it clears out. Too rich? I checked the float, checked timing, dwell, vacuum leaks and also adjusted the acc pump. Plugs look pretty decent, slightly dark. More wet with fuel then black carbon. ****er smells rich too. Idle seems to drop when sitting at a light for awhile. Picked up the calibration kit, but I don't know where to start. Primary or secondaries. It's the 1806 carb thanks
sure you dont have dirt/**** making metering rod stick open? out of the box a 650cfm is really too much carb for a 350cid Holley has an interactive carb cal for CFM and recommends their 570cfm for mild street performance 350cid - Im building a 600 vac sec holley with similar jetting to the avenger and should be just about perfect Cant find the edelbrock selector but in general I wouldnt go above a 600 performer - Since you have the 650 avs at this point I would lean both primary and secondary but be careful not to go too lean - check plugs for a bit after any adjustments - the owners manual shows pretty in depth calibration schematics
From the edelbrock manual Long Duration CamshaftIf the engine has a fairly radical camshaft it may require an excessive amount of throttle opening for idle and/or have low idle vacuum levels. Either condition can lead to poor levels of adjustability and erratic idles. • Another fix for the above condition is to run as much spark advance as possible at idle. If the distributor is fitted with a vacuum advance unit, connect it directly to manifold vacuum. If you are not able to employ vacuum advance for some reason, then the mechanical curve should have a low limit, which will allow you to use plenty of initial spark advance. • Measure the manifold vacuum at idle. If it is below 7" Hg, there is a good chance that the Metering Rods are in the up (rich) position. When combined with a high idle air rate this can cause the Nozzles to discharge fuel at idle. Use a weaker Step-Up Spring (see section on Step-Up calibration) to keep the Rods down at idle. With some cams, a stiffer spring (pink orsilver) is necessary. Experimentation is the best way to determine which is best for your application.
Thanks for the reply's. I tuned in the adjustable secondaries and got a world of difference. Took it out and mashed on it. The only sputter is if I'm at a dead stop and mash to cometely wide open throttle. So from cruising to stoping down a gear is good and off the line good unless I mash down to the floor. Pulled the plugs and they are perfect! Anyone use this carb before? I turned the flat head screw on the secondaries 2 full turns counterclockwise. (increasing spring tension) is there too much I should turn this ****er? Edelbrock said from where it's at go 1 full turn then another 3/4 if it didn't help completely. So I'm at 2 turns from the spring having no tension. Thanks! Oh and I don't have the manual for the carb, need to get one
