carb ID for this manifold
Discussion in 'The Hokey Ass Message Board' started by rogmoseley, Mar 24, 2012.
  1. rogmoseley
    rogmoseley
    Picked up this manifold several years ago and ran across it cleaning up my stuff recently. Don't know what kind of carbs fit on the adapters. It obviously takes 94-97's under the adapters, but have never seen a carb mount like this..... help appreciated.
  2. DICK SPADARO
    DICK SPADARO
    Looks like Windfield Carb pattern to early Ford adapters
  3. titus
    titus
    i figured they were just 2bll to 1bbl adaptors that you could put the carb in line or sideways.
  4. Carter
    Carter
    Those appear to be Winfield to Stromberg or Stromberg to Winfield adapters.
    I'd be interested in them if you were going to sell them.
    Thanks,
    Dave
  5. Belchfire8
    Belchfire8
    They look like these ones I have, One says CHEV on it, the other doesn't but otherwise they are identical. they were with some old Eddie Meyer V-8 60 intkaes i had.
  6. rogmoseley
    rogmoseley
    Thanks for the imput guys. Am gonna hold on to this a while longer. Always had a yen for a hot 6 inline. Had many stock ones in my time. Did a little research on the Winfield stuff, very interesting......
  7. OHV DeLuxe
    OHV DeLuxe
    from Norway
    These are not Winfield parts but adapters to put three bolt V8 type carbs on Two bolt single barrel intakes.
  8. carbking
    carbking
    I have no clue as to who made the ones in the picture; but similar units are produced today, and readily available.
    Use the search engine of your choice, and search for Transdapt.
    Jon.
  9. dmarv
    dmarv
    Alliance Vendor
    from Exeter, CA
    The adapters are to use a 1 bbl carb on a 3-bolt two barrel manifold or 3-bolt 2 bbl carburetor on a 1 bbl manifold (depends on how the adapters are drilled and tapped). Offenhauser still makes them. They are available for the 2-5/8" center to center bolt pattern 1 bbl carbs and for the 2-5/16" center to cente bolt pattern 1 bbl carbs.
    Dan Marvin, Owner
    Exeter Auto Supply
  10. Relic Stew
    Relic Stew
    from Wisconsin
    Here is a pic of some Winfields;
  11. dmarv
    dmarv
    Alliance Vendor
    from Exeter, CA
    Here is a pic of my 31 coupe.
