carb problems
Discussion in 'The Hokey Ass Message Board' started by gofast62, Aug 2, 2005.
  1. gofast62
    gofast62
    i've got a 3x2 set up on a sbc and the two end carbs flood on bumpy roads. what will fix the problem? yea i know block off the fuel to the end carbs " NOT"
  2. Buford
    Buford
    Setting the floats for a lower fuel level would be my first step. Good luck,:) Frank
  3. Yo Baby
    Yo Baby
    What he said,Lower the float level.
    T.OUT
  4. gofast62
    gofast62
    new needle & seats, lowered float , still piss's gas
  5. alchemy
    alchemy
    What kind of carbs? If it's 97's or 94's you probably have too much fuel pressure. 2 pounds is the standard for 97's.
  6. jalopy43
    jalopy43
    Perhaps you can experiment with that foam stuff,they put in lawnmowers,and stuff,to keep fuel from sloshing,with vibration? Sparky:confused:
  7. Bruce Lancaster
    Bruce Lancaster
    It would be real nice to know what carbs we are discussing.
  8. gofast62
    gofast62
    rochester 2g's
  9. Winfab
    Winfab
    Floor it every so often to **** the excess gas from the float bowls?
  10. skipperman
    skipperman
    Make sure your floats don't "sink" .... a float with a tiny leak will allow fuel into the float and it wii seek it's own level in the chamber .... to adjust measure from the airhorn to the bottom of the float ( with the airhorn INVERTED) ...I usually set a 'problem" 2G at about 1 10/32" or so ..... make sure the needle moves freeley in the seat with NO binding ( check DROP measurement too ... if it drops too far the float WILL hang up) ....
    jersey Skip
