1952-59 Ford carb spacer
Discussion in 'Off Topic Hot Rods & Customs' started by carguy699, Aug 12, 2014.
  1. carguy699
    carguy699
    hi all!
    I am trying to find a 4 barrel carb spacer with a vacuum port for my 58 fairlane 500 with the 332 fe engine. I am trying to convert to a pcv system as the road draft tube is missing and I really don't like that type system anyway. the carb is a motorcraft 4100.
    the only vacuum port on the manifold is for the power brake vacuum and I am not sure that it is a good idea to use it. i have been told that a 67-68 carb spacer will work but have not been able to locate one.
    thanks for any help that you can offer!!
  2. bobss396
    bobss396
  3. JeffB2
    JeffB2
    from Phoenix,AZ
  4. bobss396
    bobss396
  5. carguy699
    carguy699
    thanks for the replies! I have found a spacer thru summit (trans dapt trd2584) that appears to be what I need so I am going to order it and try!
    jim
  6. 68hillbilly
    68hillbilly
    from KENTUCKY
  7. carguy699
    carguy699
    ok-I received the trans dapt adapter and installed it and it worked great-got good pcv now. the holes on the adapter were slightly larger than the carb/intake venturies but the engine seems to run fine so I am going to run it and see how the engine performs. I do need to plug the road draft opening but am not sure what to use--rubber freeze plug?
    jim
