Technical Carb year ID
Discussion in 'The Hokey Ass Message Board' started by 50styleline, Sep 3, 2023.
  1. 50styleline
    50styleline
    IMG_7233.jpeg IMG_7234.jpeg IMG_7235.jpeg Can someone help me ID the year of this 2 jet? The tag is gone and no stamp by the fuel bowl IMG_7235.jpeg
  2. jaracer
    jaracer
    Looks like it has the "tamper proof" mixture screws so that puts it newer than 1973.
  3. squirrel
    Perhaps you could turn the carb around so the light shines on the side you're taking a photo of...so we could see the throttle linkage better?
    The idle mixture screws are not tamper proof, and they're easily changed...so I wouldn't base an ID on that.
    hrm2k and Bob Lowry like this.
  4. 50styleline
    50styleline
    IMG_7237.jpeg IMG_7236.jpeg Here you go and thanks for any feedback
    leon bee likes this.
  5. 50styleline
    50styleline
    No stamp so from what I re researched it’s pre 1968 but the tag has been removed
  6. squirrel
    The linkage arm looks Chevy...but they mostly had the fuel inlet on the side, and used the larger fitting with a filter inside.
    Neat mystery. Someone knows, but not me.
    hrm2k likes this.
  7. squirrel
    I think 56-58 265/283 might be it. Perhaps they started using the side fuel inlet around 1959?
    The bowl vent fitting is another clue...
  8. Moriarity
    Moriarity
    SUPER MODERATOR
    I think they started the side inlet in 65. My Rochester manual only goes up to 1962 but still shows the front inlet
  9. 50styleline
    50styleline
    image.jpg Needs a lot but it starts an 250. Wish I knew how to load videos
  10. Moriarity
    Moriarity
    SUPER MODERATOR
    Upload a video to YouTube and paste the link here
  11. pprather
    pprather
    If you are looking for a rebuild kit, if you can find one, they are now mostly generic, not ***embled for a specific carb number.
    squirrel likes this.
  12. squirrel
    Moriarity likes this.
  13. squirrel
    Mark, the 1961 Chevy service manual shows the side inlet on the 2GC.
    hrm2k, Moriarity and Truckdoctor Andy like this.
  14. pprather
    pprather
    @carbking , anything to add to this discussion?
  15. Almostdone
    Almostdone
    Rochester used the roll-stamped numbers on the float bowls beginning some time in 1968, so that puts yours before that time.
    As to the fuel inlet location….
    As I’ve understood it, the fuel inlet was changed from front to side after 1958, but @Moriarity showed us a manual that shows otherwise. I have a tuning manual published in 1957 showing a front inlet, and I found one for ‘61-65 showing a side inlet (https://carburetor.ca/manuals/cm011.html). I’m not sure what to make of all that. This is a good question for @carbking.
    edit: just saw the previous two posts!
    John
  16. Moriarity
    Moriarity
    SUPER MODERATOR
    Heck, maybe my manual was using some generic pictures.... I do know the 58 carbs on my Man a fre are front inlet
    Almostdone and squirrel like this.
  17. carbking
    carbking
    A little:
    (1) The Rochester Master Parts book has generic pictures. Go by the part number, and look up the part.
    (2) The throttle arm on the subject carburetor is Chevrolet.
    (3) Front inlets were used ON SOME MODELS as late as 1965.
    (4) As previously mentioned, roll stamps began in 1968 (a function of smog emissions).
    (5) Idle vent valves (the funky stamped steel arm and rubber valve) began on Chevrolet in 1958.
    Since this carb does not have the idle vent valve, GUESSING 1955~1957.
    EDIT: Rochester produced 3,466 DIFFERENT models of carburetor from 1949~1979. Close to half of these are 2 barrel. Making a specific statement that applies to all can often miss one (or more). Like those words "first", "last", "always", "never" that generally should be avoided.
    Jon
    vtx1800, Almostdone, pprather and 4 others like this.
  18. 50styleline
    50styleline
    I have been racking my brain trying to remember where the carb came from. A guy once gave me a box of parts after he did an LS swap. It sounds like the closest possibility. Does a 57 Nomad make sense?
  19. bchctybob
    bchctybob
    Definitely a Chevy linkage arm, no external bowl vent lever (started in 58) so I would say 1957 Nomad would be likely.
    However, Nomads being a high-end car at the time, I would be surprised to see one with a 2 bbl. No matter, it’s most likely a ‘57 Chevy carb. Good carb.
  20. pprather
    pprather
    Almostdone likes this.
  21. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Narrowing it down a bit further, the '55 carburetors didn't have the large hole in the throttle arm for a rubber bushing, so '56 at the earliest. Also, 1963 is the last year Chevrolet used the choke housing on the side of the air horn. Starting in '64, the two barrels used a divorced choke on the intake manifold.
  22. Johnny Gee
    Johnny Gee
    from Downey, Ca
    What exactly is it’s purpose? Does it really do what it’s intended for? Thanks
  23. carbking
    carbking
    The idle vent valve may be thought of as a part of the hot idle compensation circuit.
    In very hot conditions, the fuel in the bowl expands, even percolates, especially at idle (and even more true with the p/p for fuel our benevolent government thinks we need). The expansion creates pressure greater than the normal atmospheric pressure in the bowl, thus causing the balance of negative pressure in the idle wells, and atmospheric pressure in the bowl to be disrupted. This causes more fuel to be placed in the idle circuit. In short, the idle vent valve helps to prevent the engine running too rich, possibly stalling, due to additional pressure in the bowl.
    This feature is also aided, at least on SOME Rochester carburetors, by the slotted throttle body to bowl gaskets. While the idle vent valve relieves pressure in the bowl, the slotted gaskets relieve pressure above the thottle plates.
    Jon
    jimmy six and Moriarity like this.
  24. jimmy six
    jimmy six
    Carburetors were miraculous mechanical devices which could compensate for changing conditions without a wire in sight. Amazing instruments in their prime and still today.
    carbking and squirrel like this.
  25. 50styleline
    50styleline
    Thanks for the info. Knowing this could be valuable as I live in south Texas
  26. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Thank you. Here’s why I asked. Early unit had a very small vent at the air horn so ok it makes sense. But later unit received a much larger vent with tube at the air horn but still have the idle air valve.
