1/32" clearance between carbs, 6 nuts that are next to impossible to tighten, special fabbed wrench to get at the********s, 3 hours in a 90 degree shop. Piece of cake. Can't wait to do the linkage. Sure as hell makes the beer taste good.
I don't understand????? Did you put on the front two first then the middle two and then back two.. Linkage should have been built with bodies off so you could see the throttle plates move to make sure it's right.. Duane..
