Customs carbs, intakes, and exhaust questions
Discussion in 'The Hokey Ass Message Board' started by Holyman, Jan 26, 2017.
  1. Holyman
    Holyman
    so last thread was deleted, that's cool i didn't read the guidelines prior to posting. I should have specified that i am swapping the 250 out of my 73' into my 63'. I have a 63 gmc and a 73 gmc. i prefer the 63 but the rings are blown and it has a 305 as well as a busted ******. i was going to take the 250 out of my 73 as well as the ******. rebuild the 305 and put that with a reman transmission in my 73.
    so i am wanting to find an alternative carb for the 250 as well as intake maybe, as well as possible combinations of stock intakes w/ after market carbs.
    i am wanting to keep the egr system so i thought about punching a hole in each of the header collectors and welding a bolt there to connect SS lines that feed to the bottom of the intake.
    does this pertain more to the H.A.M.B.? It fits the year requirement and the custom build.
  2. Rex_A_Lott
    Rex_A_Lott
    I cant think of any good reason to keep the EGR, but maybe there is one I dont know. If its just a stock engine, the stock carb is plenty OK for a 250. Hot rodded up may be a different story.
    You really ought to give more details on what you expect.
    Good Luck
  3. Atwater Mike
    Atwater Mike
