Technical Carburetor choices
Discussion in 'Traditional Hot Rods' started by robert graves, Jun 14, 2024.
  1. robert graves
    robert graves
    Rebuilding a 241 dodge red ram hemi and all I’m seeing available is a 3 Duce manifold to upgrade , so what carburetors are best suited for a 10/1 compression 240 lift hyd cam wit stock dim. heads to not over carburetor it ? All help appreciated
    Tow Truck Tom likes this.
  2. 55blacktie
    55blacktie
    Holley has a 4160 390 cfm 4-barrel carburetor (0-8007) that would do well, if you have the right manifold/adapter, but it's not cheap. You want to keep the cfm rating around 400/w vacuum secondaries.
    New reproduction Offenhouser 4-barrel manifolds are available and include an adapter for Holley carbs, P/N 50013, $750.
  3. gimpyshotrods
    gimpyshotrods
    I have a customer running a 270 Red Ram.
    It has three 94's with 2.5-in-Hg power valves. It runs on the center, with the outer two coming in at 50% throttle, only opening half-way.
    It runs great.
  4. Bandit Billy
    Bandit Billy
    I’d totally run a trio of 97s on that red ram. The legit ones from England not speedway's ones made a bit west of California.
    I’ve been running three of them on my blown Flathead for 5 years now without issue.
  5. continentaljohn
    continentaljohn
    I had a tri power on my 241 and tried both the stromberg 97 and ford 94s . I ran the 94s for about 5 years and like @gimpyshotrods said running of the center and my outer carbs ran a bit tighter at about 70%.
    I tried a 4x2 but had to run 97s because of size and needed another distributor as it’s tight. I ended up with a 6x2 from a buddy @silent rick and still run that today . I tried using all 6 using 81s but ran Fat and started blocking off carbs to get a good combo. The setup now has two 48s in the center and blocked off ends . I know it’s not right to block off carbs but the setup looks wicked cool. I have another motor I’m building and that one will have enough balls to run all 6 carbs.
  6. silent rick
    silent rick
    John, have you tried 81's, either on the 4x2 or at the corners on the 6x2?
    continentaljohn likes this.
  7. silent rick
    silent rick
    haven't fired it yet but I have a pair of 250 cfm big flow 97's on a 2x2 edmunds, it's 10:1 with larger 270 intake valves and a re-ground cam
    I also have a weiand 4x2 and drag star
  8. robert graves
    robert graves
    I thought that was for the 315 and 325 ? Will it fit the 241 ?
  9. 6sally6
    6sally6
    600 cfm Holley (with vac. secondaries) work great on my old 260+.30 SBF back in the day.
    Does anybody make a hi-rise intake for the Lil Red Ram ? There's a lot to be said for simplicity....
    6sally6
  10. 55blacktie
    55blacktie
    241/270. hothemiheads.com
    I like the look of the 2 x 2 250s, but I think fuel distribution with carburetors on the opposite ends of the manifold would be less than optimal. In that regard, I think a single 4 barrel would be better (and simpler). Sometimes you have to choose between looks and performance, but cost is also a consideration.
    The WCFB carburetor was rated 400 cfm.
  11. 55blacktie
    55blacktie
    Robert, you might find this helpful: victorylibrary.com/Mopar/dodge-c3.htm
    Here's another: speedway motors.com/the-toolbox/241-hemi-long-block-rebuild-part-one/28671
    There's also a Part Two
  12. continentaljohn
    continentaljohn
    @silent rick I haven’t tried the 81s in the corners yet and will do that on my new motor if she runs fat.
    I do like the look of the 2x2 and with 250cfms that should run great plus with the Flamethrower that’s a awesome setup.
