carburetor cleaner question
Discussion in 'The Hokey Ass Message Board' started by jazzbum, Sep 16, 2005.
  1. jazzbum
    jazzbum
    so, i am rebuilding my carburetor (again) and this time around, i have no shop to use the parts cleaner in. this is fine, except i can't find bulk carb cleaner ANYWHERE - only the chintzy aerosol cans that have like ten ounces in them and are no good for dipping anyway. so, does anyone know where i can get about a gallon of carb cleaner, or, failing that, a decent subs***ute for it? i have found laquer thinner and acetone all over the place - will this work, or does it leave a residue? oh, the carb is an edelbrock performer, aluminum body. thanks!
  2. Paul
    Paul
    Editor
    I use this stuff, it works ok, got it at the local National Auto Parts store
  3. oldcarfart
    oldcarfart
    you ain't gonna find **** in calif., I use berkebile 2+2 gum cutter and it says right on the label that it is illegal to posses in calif, nix on shipping to the left coast either.
  4. ponchoman
    ponchoman
    Yotta be able to get Chemtool in 1 and 5 gallon sizes, even in LALA land. If you got NAPA stores out there, give 'em a shot.
  5. Bugman
    Bugman
    If you can't find anything else, miniral spirits and a toothbrush works well, and leaves no residue.
  6. Bluto
    Bluto
    Yamaha makes some stuff you mix with water and heat a bit
    I comes in plastic bottles like oil ....... most of the dealers around here don't carry it but it's good stuff!!!
  7. jazzbum
    jazzbum
    thanks guys.
  8. MAW
    MAW
    I bought a 5 gallon can of McKays carb cleaner at a NAPA shop 6 months ago. That store (Huntington Beach, CA) still stocks it. There's actually only 3 gallons of solvent inside.
    Regards, Mark
  9. jabber
    jabber
    you can use laquer thinner, it works fine and is pretty cheap.
