Carburetor Help!!!
Discussion in 'The Hokey Ass Message Board' started by Infernus, May 29, 2006.
  1. Infernus
    Infernus
    from Canada
    Alright here's my dilema, I have a 1948 Pontiac with an inline 6, but the engine is not original and I need a carb kit for it, I believe the engine is out of a 1955 Pontiac but I could be wrong, but the carb in there is a GM Rochester Carb #7003536, so my first question is does anyone know where I can find a rebuilt kit for that?
    Next question is, I found on ebay an already rebuilt rochester carb #7005922, does anyone know how interchangeable these carbs are, cause this one looks VERY similar to the one I currently have, any help would be greatly appreciated.
  2. burntclutch
    burntclutch
    from N.E. La
    Go to your local parts house and give them the number,and make and model of your ride and they will get a rebuild kit for it,should be about 14.00$,the kit you get will have stuff left over because the kits cover a variety of 1bbl rochester carbs.
  3. cjb40
    cjb40
    The number you listed is a casting number. You will not find these numbers in any Rochester publication. They are a “part” number for the unmachined casting. The casting can then be machined in a variety of ways, and the machined casting will then be given an actual part number. Your carb is p/n 7005922. See these links for your kit.
    http://www.carburetor.ca/carbs/kits/CK010.htm
    There are many more to numerous to list. Look for the 235 engine application in the links.
    Tag 7005922 – bowl casting 7003536 – throttle body casting 5922
    Hope this helps!
  4. gimpyshotrods
    gimpyshotrods
    Dude, this thread is 4 years old.
