Can someone help me identify this carb? I think it’s a Holly 97? It has a “Ford” and “1-1/16”” marked on it. I don’t want to order the wrong kits. Thanks in advance for the help.
Try a Holley '94', its a 'late' bigbore version - usually most kits will have all the various bore size gaskets. Generally these have the spark valve on the throttleplate, it looks like a powervalve but is intentended for timing control.
Here is a link to help identify your carb and buy parts. https://www.vintagespeed.com/carbs/. Are you going to use more than one of these on one engine? What engine ? i.e. flathead, y block , etc.
Most call it a Holley 94 or as said above large bore 94 means 0.94 of an inch What is shown is 1&1/16” , slightly larger and gives a bit more get up and go than the smaller 94. A few bits missing from the one shown.
