Hot Rods Carburetor info
Discussion in 'The Hokey Ass Message Board' started by jjjmm56, Dec 15, 2025.
  1. jjjmm56
    jjjmm56
    from FL.
    Can anyone tell me what carbs these are, and CFM if you know.
  2. Moriarity
    Moriarity
    SUPER MODERATOR
    Rochester 2gc carbs that are typically rated at 285 cfm
  3. 19Eddy30
    19Eddy30
    from VA
    Rochester 2G 285-as much as 500
    Search part# for cfms ,,,
    There are small base & big base .2Gs
    One's shown small base.
    Those air filter covers are very restrictive
    Sharpone likes this.
  4. HEATHEN
    HEATHEN
    from SIDNEY, NY
    They look like the small bolt pattern variety that were common on Chevrolet 283s and 307s.
    Sharpone and Moriarity like this.
  5. Moriarity
    Moriarity
    SUPER MODERATOR
    his look like small base carbs. No way that his are 500 or anywhere near
  6. 19Eddy30
    19Eddy30
    from VA
    I know small base not 500 ,
    Sorry for the confusion to the OP
    I was just pointing out 2gs can be up to 500 cfm's ,, I have a big base 2G I believe
    A one year 625 or 650 cfm ,
    Olds or Buick maybe Pontiac , BB
    I think 71 or 72 ,
    I try to be accurate , I have so many parts over 55 years , just in carbs 45 plus. Maybe early signs of Alzheimer's?
    Budget36 likes this.
  7. tubman
    tubman
    I believe there are 500 CFM 2G's, but I think they're special racing versions. Years ago I ran in a cl*** that mandated a race-ready spec Holley 2bbl. When I went to buy one at Speedway, they offered the racing carb in 350 CFM and 500 CFM versions. I believe I saw 350 and 500 2G's in the same section of their race parts catalog. It's hard for me to believe that GM sold one on a car that flowed that much.
  8. lake_harley
    lake_harley
    For sure but then you lose the fun of showing what you've been able to do with a "little" Rochester 2GC.:eek:
    Lynn
  9. GTS225
    GTS225
    Just to kick up a little memory; Anybody remember the m***ive Holley 650 annular discharge 2-barrrel?
    Roger
  10. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Yes, didn't they have built in velocity stacks?
  11. GTS225
    GTS225
    I don't remember a stack, but they did have the choke horns milled off.
    Roger
  12. 270ci
    270ci
    Don't forget that two barrel carbs are rated differently than four barrel carbs.
    A 500 cfm two barrel does not flow as much as a 500 cfm four barrel.
  13. carbking
    carbking
    I remember a truck 2G with a governor, that memory (sometimes wrong) says had a 1 7/16 venturi.
    I don't still have one to check, and of course the Rochester parts book do not give this information, but it was from the 1970's.
    Jon
    jet996 likes this.
