Technical Carburetor Issues?
Discussion in 'The Hokey Ass Message Board' started by Doah1079, Dec 8, 2023.
Tags:
  1. Doah1079
    Doah1079
    I recently installed a new Edelbrock Performer RPM intake and an Edelbrock AVS2 650cfm carb onto a sbc 350, and ever since then I have been having some issues. My main issue is that while driving, randomly, the engine seems to lose power and my gas pedal seems to lose all response. However, the engine still idles and sometimes may recover or will die once I pull over. Could my floats be off?
  2. Wanderlust
    Wanderlust
    I’d suggest checking the output from the fuel pump, did you also replace the fuel hoses?
    Johnny Gee and jaracer like this.
  3. jaracer
    jaracer
    Do you have a fuel filter? If so, I'd take a look at it.
  4. Doah1079
    Doah1079
    I replaced the fuel lines with steel braided ones prior to the new intake and carb, and my fuel pressure is at 6psi and I'm installing a pressure regulator later this week to turn that down.
  5. Doah1079
    Doah1079
    I have a filter between the tank and pump and one between the pump and carb. I can double check both to see if there is any junk in them.
  6. Wanderlust
    Wanderlust
    I’d next check your grounds, what are you running for ignition?
  7. Doah1079
    Doah1079
    Okay, I'll check those. I'm running an accel hei distributor.
  8. dogwalkin
    dogwalkin
    from tn
    Electric or mechanical pump? If mechanical i would lose the filter before the pump.
  9. Doah1079
    Doah1079
    It's mechanical. I'll remove the filter and give it a try
  10. Wanderlust
    Wanderlust
    Not familiar with accel’s version, but I’d also check the distributor carefully ie wiring, connectors, rotor ****on, carbon tracking in cap, mechanical advance etc.
  11. Glenn Thoreson
    Glenn Thoreson
    from SW Wyoming
    Cl***ic symptoms of fuel starvation. The gas is not getting into the carb fast enough to keep up with the usage. It is enough for idle but not enough to keep up with a load. Check filters and eliminate the one between the tank and the pump. Pumps are great for making pressure but bad for suction. Disconnect both ends of the gas line and blow it out with compressed air. Check the pump pressure and disconnect the line at the carb, stick the line in a can and check for output by cranking the engine with the ignition disabled. Check the carb inlet to make sure there's not a little filter in the inlet. If all checks out the float setting may be the problem. Also check the gas cap to make sure it's vented and working. A plugged vent hole in the cap can create a vacuum in the tank and create fuel starvation. Hope this helps.
    Edit: If that HEI distributor uses the GM flat pickup inside the distributor, Change it with a new or known good one. These things are often bad right out of the box and can mimic a starvation issue.
  12. ClayMart
    ClayMart
    ^^What he said.^^
    And if installing a new (or different) ignition module be sure to use thermal paste on the bottom of it, not just dielectric grease.
    Wanderlust likes this.
  13. Doah1079
    Doah1079
    I will definitely try everything that has been suggested when I can. Once I do, I'll drive around and report back and see if things have improved.
    leon bee likes this.
