Technical Carburetor, Left Turn Stumble ??
Discussion in 'The Hokey Ass Message Board' started by Wyld Deuce, Dec 20, 2020.
  1. Wyld Deuce
    Wyld Deuce
    from ...
    I have a Holley 4160, I have had it since 2008.
    I had it rebuilt 5 years ago.
    It has always work fine until recently, Found the problem to be a dried up accelerator pump diaphragm and the power valve diaphragm was getting stiff.
    I replaced both components.
    Now the carb has developed a new issue ,,,, left turn stumble.
    This is a new one on me, What causes a stumble only on a left turn?
  2. dirty old man
    dirty old man
    Usually it's the float level setting.
  3. HOTRODPRIMER
    HOTRODPRIMER
    I agree. HRP
    Deuces likes this.
  4. Bob Lowry
    Bob Lowry
    Ditto from an old Holley guy....
    Deuces and Frankie47 like this.
  5. Elcohaulic
    Elcohaulic
    I thought this was going to be a Carter AFB for sure but nope...
    millersgarage likes this.
  6. Wrench97
    Wrench97
    Another vote for float level.
    Deuces likes this.
  7. Hud I
    Hud I
    from Tennessee
    Ditto on the AFB.
    Elcohaulic likes this.
  8. Boryca
    Boryca
    from Detroit
    Agreed with above float level setting. Side-hung floats give you troubles in corners, center hung floats give you troubles on acceleration/deceleration.
  9. Dedsoto
    Dedsoto
    from Australia
    I had a flying ant or insect of some sort find its way into the primary bowl of a 600 vac. Ended up stuck in a main jet and caused a similar issue.
  10. Steves46
    Steves46
    from Florida
    Agree with the others. I had the same issue on my 55 F100 and a float adjustment resolved it. Hopefully this will be the same for you.
  11. Deuces
    Deuces
    Yep! What they said...... Also re-adjust the acc. pump arm so you have .015-.020" clearance at wide open throttle when you bolt the float bowl back on the carb.... ;)
  12. Deuces
    Deuces
    Did you get it fixed????......o_O
  13. Wyld Deuce
    Wyld Deuce
    from ...
    Thanks for the tip, will have to make some adjustments.
    Deuces likes this.
  14. Deuces
    Deuces
    Cool!... Let us know how it runs when you git it done please... Thanks!... ;)
  15. Lloyd's paint & glass
    Fuel pickup in the tank broke off.
  16. Wyld Deuce
    Wyld Deuce
    from ...
    Carb was on a slow death to rebuild.
    Throttle body flooded itself in short order.
