Technical Carburetor Paint?
Discussion in 'Traditional Hot Rods' started by ‘28 RPU, Mar 2, 2024.
  1. ‘28 RPU
    ‘28 RPU
    I’m wondering what is a good paint (spray bomb in a can) to use on the cast Iron carburetor bases?
  2. SS327
    SS327
    Cast iron grey?
  3. Lone Star Mopar
    Lone Star Mopar
    loudbang and Deuces like this.
  4. Lone Star Mopar
    Lone Star Mopar
    Also Id suggest using high temp clear on underhood cast parts like intakes ect... makes cleaning off grease & oil much easier.
    Speccie and Deuces like this.
  5. DreamerJ
    DreamerJ
    I used a high temp engine paint in gloss black. Like a vht or duplicolor Seems to be working great and durable.
    Deuces likes this.
  6. Rickybop
    Rickybop
    You said spray bomb. But have you looked at cerakote? Super durable.
  7. Bandit Billy
    Bandit Billy
    I received an email from Clive the other day at Stromberg, he said they have had good luck using automotive base coat but not clear on their bases. Just p***ing it along.
    GordonC likes this.
  8. I use Cerakote - the version that you bake on. It is impervious to gasoline - which every paint I ever used was not. I've had it on the bases of my Stromberg 48's for 6 years - if it gets dirty, I take a toothbrush with lacquer thinner to clean it off. Surface prep is mandatory - you must blast the bases before you apply the coating and you can't touch the parts with your human hands once you blast, pre-bake, apply the coating and final bake.
    Desoto291Hemi and loudbang like this.
  9. I used black appliance epoxy, Rustoleium I think…..
    RICH B, Lone Star Mopar and Speccie like this.
  10. TCTND
    TCTND
    I powdercoated the bases of some Strombergs for a local flattie powered deuce about 25 years ago. Still looks great.
  11. V8-m
    V8-m
    from Alaska
    I will use black zinc on my carb bases.
  12. '29 Gizmo
    '29 Gizmo
    from UK
    A lot of rattle cans like are not fuel resistant, including a lot of rustoleum products. always check a sample.
    I use domestic enamel based paint (direct to metal) or powder coat.
    Enamel rattle cans have a much longer drying time so you can often tell by the product description.
  13. larry k
    larry k
    I use por 15 on sand blasted iron , and it gas proof also !!!
  14. BJR
    BJR
    Nothing I have found hurts KBS.
  15. hepme
    hepme
    Used wheel paint on several, never had a problem w/ temp or gas leakage.
  16. Rickybop
    Rickybop
    I think many paints gain durability when baked.
    theHIGHLANDER likes this.
  17. theHIGHLANDER
    theHIGHLANDER
    If there's gas all over the carb the paint on the base is the least of your worries. Packard carbs are completely painted. I used to use black Deltron, then I switched to lacquer in restoration work? Why? Packard said so. Most of em are still shiney black today from decades ago. Some modern gas eats at everything but so far so good. Granted many of them haven't accrued 100k miles but...
    Desoto291Hemi likes this.
  18. ‘28 RPU
    ‘28 RPU
    I generally bake anything that will fit into (my wife’s) oven.
    RICH B likes this.
  19. Don't bake cerakote in your wife's oven . . . unless you're looking for a new wife! I use a big BBQ and depending on the coating, sometimes I have to go up to 500+ degrees (ceramic coating flathead headers!).
  20. I've used VHT caliper paint with good results so far. After baking it's supposed to be chemical resistant, most specifically I suppose to brake fluid, but so far alcohol laden gas as well. It's been less than 2 years though so I guess time will tell.
  21. Ducbsa
    Ducbsa
    from Virginia
    Model airplanes use a paint that resists nitromethane.
  22. nrgwizard
    nrgwizard
    from Minn. uSA
    ^^^ Usually referred to as "Hot-Fuel Proof" Dope, specifically for the U-Control or Radio Control flying models.. Resistant to methanol, nitro, castor oil, benzene & other neat-n-cool additives... :D .
    I've used a generic spray-bomb epoxy paint(keep it outta your lungs & off your skin, it's nasty stuff) years ago that worked well, but like other said, prep is key. Don't know how it'd work w/todays' pantherpiss-for-fuel, or the alky-laced stuff.
    Marcus...
