Hot Rods Carburetor Selection
Discussion in 'The Hokey Ass Message Board' started by Yamanine, Jun 26, 2018.
  1. Yamanine
    Yamanine
    I need some input from fellow Hambers here. I have been building 40's model Ford pickups for many years now, and they all have had the same problem. I have been bee using SBC and SBF stock engines, with just an intake upgrade and an edelbrock perfomer carb (600 cfm). The will all rev to the moon in park, but when i drive and hammer down, it just seems like it's not rapping out. It doesn't spit and sputter or act like it's starving for fuel. It just seems that under a load, it doesn't get up and go like it should. Could it simply be that i'm using too large of carburetor??? I currently have a SBC 305 and I need to buy a new carb. I'm thinking about buying an Edelbrock 1403 which is 500 cfm. Any help would be very appreciated.
    Bowtie Coupe likes this.
  2. squirrel
    The carb is fine, it's that the engine needs to be bigger!
    I'd also be thinking about gear ratios, stall speeds, cam specs, etc. Everything on the car needs to be designed to work together, and if you want performance, you need to up your game on all of it.
  3. George
    George
    500 CFM is close to what the formulas call for, but 305 is not much CID for get up & go.
  4. Yamanine
    Yamanine
    I knew i was gonna catch hell for that 305... I'm not really looking for performance, i just wanna get on it every now and then and enjoy the brief shot of power. When I first stand on it, it hesitates for a second then picks up. I'm running 3.73 gears, small tires and a stock late 80's camaro engine that I converted to carburetor.
  5. Yamanine
    Yamanine
    The last was a 351 Windsor, before that was a SBC 350
  6. Yamanine
    Yamanine
    All have acted the exact same way.
  7. Tickety Boo
    Tickety Boo
    from Wisconsin
    Have you been keeping the original fuel lines? I know my 48 had a very small fuel line to feed a sbc and changed it to 3/8 line.
  8. Bandit Billy
    Bandit Billy
    :cool::rolleyes:
  9. Yamanine
    Yamanine
    All new 3'8" fuel line, new Carter electric fuel pump.
    Bowtie Coupe and Tickety Boo like this.
  10. George
    George
    As squirrel said, there's a lot involved. compression, CID, cam, rear gears (I had a '79 Ford SW with a 351W/c4, turned out it had 2.25 rear gears in it!) , and the transmission, all figures in. The fuel lines on my '48 Plym were adequate.
  11. Yamanine
    Yamanine
    I guess I'll try a 500cfm carb and see how it does. I'm currently running a 700r4 with 3.73 rear end gears. It may just be as you all mentioned. A small displacement, stock engine. I'm expecting something that just isn't there.
  12. squirrel
    you can try a smaller carb, and see how it works. But without knowing all the details of what you have now, we can't say for sure that it will help.
    Make sure the accelerator pump is working properly, the timing and advance curves are the best they can be, the engine is in good shape, etc.
  13. Yamanine
    Yamanine
    Thanks Fellas!
  14. LM14
    LM14
    from Iowa
    Have you done anything but bolt the carb on and drive it? Tuned everything? Are you using a restrictive exhaust system? Does the distributor have vacuum advance and is it working? Correctly? Have you checked fuel flow?
    SPark
  15. Yamanine
    Yamanine
    All those things check out. It's got open lake headers, standard rise aluminum intake, new spin aluminum fuel tank, all new 3/8" fuel lines, new Carter electric fuel pump, new distributor, new plugs and wires.
  16. Budget36
    Budget36
    How much fuel pressure does that Carter pump put out? Edelbrocks won't take 9-10PSI very well.
  17. Yamanine
    Yamanine
  18. jimmy six
    jimmy six
    Advance the cam 6*...
  19. Jibs, bobss396 and Deuces like this.
  20. rjones35
    rjones35
    One thing you have probably checked, that I didn't once upon a time many years ago...... make sure you're actually getting full throttle. I could never figure out why I didn't have more get up and go. Turns out that when I replaced the carb and intake, i ***umed that the throttle linkage I had would make the carb open all the way when I stepped on it. It didn't. Only about 1/2. I was young and dumb, what can I say.
    czuch, scotty t, Bowtie Coupe and 2 others like this.
  21. squirrel
    that happened to me last year....and I ain't young any more. Still dumb, though
  22. Yamanine
    Yamanine
    I will definitely check that. It could be the culprit. I'm using a speedway adjustable s**** pedal. If I have it mounted high, and the pedal adjusts low to reach, it could cause a short throw. That's exactly what it acts like. Like the secondaries aren't opening. I'll check it tomorrow and let you guys know. Thanks again!
    Sent from my SM-G950U using The H.A.M.B. mobile app
    Bowtie Coupe and rjones35 like this.
  23. rjones35
    rjones35
    There you go! Maybe it'll be a simple fix!!
  24. ChevyIIman65
    ChevyIIman65
    I had a 305 in a 79 4 door nova 2.73 gear turbo 350 with shift kit stock convertor stock 305 with comp 280h with springs double roller timing set edelbrock aluminum intake edelbrock 600 carb truck headers cherry bomb mufflers no power steering just running alternator an it didnt have no bottom end comin off the line but it sure would fly once you got the rpms up i imagine if i had a good gear and loose stall it woulda hauled hindend but it sounded great an ran great an had good power all around i though
    Sent from my LG-LS777 using The H.A.M.B. mobile app
  25. 4wd1936
    4wd1936
    from NY
    If you are spending the money I would go 600 CFM for a 305. Hint, I have one listed in the cl***ified section.
  26. ChevyIIman65
    ChevyIIman65
    I have a 305 on the stand now i got for free with 601 ho heads im gonna try to port an do some work to the heads an raise the compression an stab the same 280h cam like i had in my last 305 to put in my chevyii but this time a manual 3 speed and thinkin ima put 4:10 or whatever gear in it im sure itll be way better than the last i like 305s cause nobody wants em and if your not drag racin or doin anything ******** they run good and serve there purpose
  27. Mr T body
    Mr T body
    Alliance Vendor
    from BHC AZ
    Going smaller than a 600 will buy you absolutely nothing, but going to a Holley over an Edelbrock will likely buy you something.
    Deuces and coolhandponcho54 like this.
  28. Deuces
    Deuces
    :D
  29. Deuces
    Deuces
    Do you have the vacuum advance line hooked up to full manifold vacuum?????
    You might want to give that a try......
    czuch and Bowtie Coupe like this.
  30. Some of you guys would be surprised at how many 10 second Stock cl*** drag cars, and 9 second Super /Stockers there are out there..Oh, and NONE of them have Holley carbs;)
