Technical Carburetor size 241 hemi
Discussion in 'Traditional Hot Rods' started by robert graves, Jul 8, 2024.
  1. robert graves
    robert graves
    I thinking of running 3/2 barrel carbs on a 10/1 comp stock valve 420 lift cam set up . will 3 hollley 94’s be too much ? Anyone got a jet and power valve size for a good starting point
  2. George
    George
    1st thing...will 94s fit on your intake? Many will take 97s only.
  3. Bandit Billy
    Bandit Billy
    A trio of 94's or 97's aint gonna get over 400 CFM all kicked in. Should be a fine fit for the little Hemi
    Tow Truck Tom and robert graves like this.
  4. lake_harley
    lake_harley
    My quick calculation (subject to error) comes up to 348 CFM at 5,000 RPM. At that rate a 350 Holley 2-barrel would do for street driving, but granted 3-2's would look cooler.
    Lynn
  5. robert graves
    robert graves
    I want the cool factor, going in a 1936 ford pickup , thanks for the info
    osage orange likes this.
  6. dart4forte
    dart4forte
    from Mesa, AZ
  7. Bandit Billy
    Bandit Billy
    I have seen threads on guy's running 3 "big 97's" and having a tough time tuning them down on smaller displacement applications. I wonder if anyone has used a big 97 in the center as the primary and run the outer two regular 97's on a progressive linkage? Provided the intake will accommodate it. Maybe an email to Clive is on order?
    Tow Truck Tom likes this.
  8. Andy
    Andy
    You going to run solid lifters? It is had to get lift in these engines. The hydraulic lifter has to be in a specific place to pump up.
    I ran two 97’s and they were fine. I changed to a 54 Buick wcfb and it is still on the engine.
    The three twos should be fine as well.
  9. tubman
    tubman
    I think 94's would fit on that manifold. (They sure didn't on a Weiand "4-in-a-row" I had on a big Chrysler). If I could afford it and could find them, I'd opt for 3 Stromberg 81's. IIRC. Pontiac used to run their "Tri-Powers" with a small base 2g in the middle and large base units on the end. How does an 81 in the middle and regular 97's on the ends sound? I have heard "big" 97's flow 250 cfm; three of those would almost certainly be too big.
