Technical Carpet underlay
Discussion in 'The Hokey Ass Message Board' started by CadGuyUSA, Mar 5, 2017.
  1. CadGuyUSA
    CadGuyUSA
    How does new stuff like hushmat and dynomat compare to the old rubber tar underlay (I'm not sure what they were made out) that were stuck to the floors of cars in the 60's and 70's?
    Does the old rubber stuff have any advantages?
  2. Latigo
    Latigo
    I'm laying down some Dynamat now for the first time. Can only go on what the manufacturer claims as to its effectiveness. However, after pulling up the old underlayment I suspect the Dynamat will be a major improvement. Ain't cheap but I've read some posts of folks using similiar type products from home supply stores that they felt worked pretty well too. I may consider that in the trunk area.
    lothiandon1940 likes this.
  3. Have Dynamat in my avatar, installed nicely and makes it water tight, used foil tape on the seams. You can go online and buy Dynamat look a like underlayment for a lesser price, have used some of that stuff as well and noticed no difference in quality. And I almost forgot, welcome to the HAMB!
  4. CadGuyUSA
    CadGuyUSA
    The old stuff seems more dense/solid to me. Not sure if it's still being sold, but ***ume it is.
  5. wbrw32
    wbrw32
    The old "jute" padding is still available at most good upholstery wholesale suppliers..sold by the yard...
  6. CadGuyUSA
    CadGuyUSA
    Not the fiber jute padding. The rubber tar type stuff.
  7. gene-koning
    gene-koning
    Do NOT use the jute backing, it holds water against your floors for almost 2 weeks after it gets wet.
    I suggest a truck paint in bed linner type product. You need something to seal the metal and keep the moisture off the floor pan. Floors rust out from the top/inside down. Gene
    Barn Find likes this.
  8. Never2low
    Never2low
    Are you looking to deaden panels that are resonating, or are you looking to block out road noise?
    Dynamat's intended purpose is to suppress panel vibration, while absorbing some road noise.
    And contrary to popular belief, does not require 100% coverage to be effective. 30-50% is sufficient, when applied in the correct locations.
    If you want a true sound barrier, use a layer of MLV (m*** loaded vinyl) over the dynamat.
    Its black rubbery mat about 1/8" thick, and it's heavy! Approx 1 lb per sqft.
    The stuff from Home Depot isn't bad, but a lot of people report it off g***ing (fresh tar smell) when it gets hot in the sun. (I've never used it, so I can't comment 1st hand)
    Check out KnuKonceptz for their Kno Knoise deadener, it's cheaper than Dynamat, and just as good.
    http://www.knukonceptz.com/mobile-audio/sound-deadening/kno-knoise-resonance-control/
    Fatmat is another budget friendly alternative to Dyn.
    https://www.amazon.com/s/?ie=UTF8&k...&hvtargid=kwd-24903083&ref=pd_sl_5w9a18aigr_e
    Secondskin has very nice products, but they're not cheap.
    http://store.secondskinaudio.com/damplifier/
    MLV link;
    https://www.amazon.com/Loaded-Vinyl...=1427585168&sr=8-2&keywords=m***+loaded+vinyl
    gimpyshotrods likes this.
  9. Al Consoli
    Al Consoli
    I've used the Xmat from Eastwood in 2 cars. It's the same as Dyamat at about half the price.
  10. Never2low
    Never2low
  11. 29moonshine
    29moonshine
    the stuff from lowes is tar base [it burns real fast]
  12. CadGuyUSA
    CadGuyUSA
    So any thoughts regarding the old rubber based mat?
  13. gimpyshotrods
    gimpyshotrods
    I am a big fan of m***-loaded vinyl. I have a big roll of it, in 1/4", that I have to move with a forklift.
    It only needs to be adjacent to things that make noise. Elsewhere it is wasted, and just adding weight.
    It is seriously heavy. I put it over 1/8" closed cell foam, and that over Fat Mat, for a luxury car like quiet. Above all of that, thinner than normal (to make room for everything underneath) carpet padding and carpet.
    You can still annoy the neighbors, without losing your own hearing!
    ace5043 likes this.
  14. Barn Find
    Barn Find
    from Missouri
    As someone who drives their old iron every day, these are real concerns for me. I've even been concerned that the paint-on bed liner could loosen and hold moisture-like a lot of old undercoating I've seen. I use a rubber truck bed mat on the floor against the steel Those heavy mats have little bumps that hold air gaps along the steel. They don't conform well to curves, but they work great on flat floors. You can put a carpet or rubber mat on top of them and they hold the sound down pretty well.
  15. bobss396
    bobss396
    I used Fat Mat on my Ford. My buddy who helped put it down said it was more flexible than Dyna Mat and 1/2 the price.
  16. rusty rocket
    rusty rocket
    I used the stuff from lowes used for wrapping around windows of a house. Twenty bucks a roll and it sticks like mad. I think I used two and a half rolls, Double on the firewall.
  17. rusty rocket
    rusty rocket
    bobss396 and patmanta like this.
  18. I don't suppose the "old stuff" had/has any advantage unless you're a purest building a museum piece. The "new stuff" has the advantage of newer tech and material, and probably not as messy. The aluminum foil probably helps a little with temperature insulation, too.
  19. southerncad
    southerncad
    Or if the noise is too loud....the cheapest fix is...
    ...just crank up the radio:D
    Hudson31 likes this.
  20. CadGuyUSA
    CadGuyUSA
    After doing some research I believe this to be about right. I don't know that the newer stuff is any better at sound deadening, but it seems that both old and new is butyl rubber based. I thought the older stuff was possibly better because it was heavy and/or more dense, but looking on Dynamat's website they have some thick 3/8" stuff now as well.
  21. Never2low
    Never2low
    That's not peel and stick butyl based panel deadener, that's a thermal and acoustic padding for under the carpet. It's a hybrid of MLV and closed cell foam.
    You can use that, but you may still get panel resonance (that tin can sound).
    You're best bet is to use 30-50% coverage of Fatmat and a complete coverage layer of the MLV I linked.
    Please note that normal adhesives will not stick to MLV.
    Weldwood Landau top and trim contact cement, is highly recommended.
  22. gimpyshotrods
    gimpyshotrods
  23. CadGuyUSA
    CadGuyUSA
    That's true. Thanks for the correction. How thick is their heaviest rubber product?
  24. gimpyshotrods
    gimpyshotrods
    I use the 70mil MegaMat.
  25. Never2low
    Never2low
    The Knu Konceptz I linked offers two sizes. 80 mil and 100 mil. Obviously the 100 is more expensive.
    Pretty sure Fatmat offers similar thicknesses.
  26. CadGuyUSA
    CadGuyUSA
    100 mil as in 0.100"?
    The old stuff I just pulled was thicker than that.
  27. Never2low
    Never2low
    80 mil is 2mm thick or .078" so yes the 100 is about .100".
    Coming from a Compe***ion Car audio back ground, I can't think of too many times I've had to use a 2nd layer, because the first layer wasn't effective enough.
  28. The 39 guy
    The 39 guy
    I used Dynamat throughout my coupe. I added the 3/8 thick foam product on top of the Dynamat on the firewall. I am very happy with it. Except my noise sensitive wife is complaining that she can hear the odometer turning over in the speedometer...........:rolleyes:. That how quiet it is. Probably should have used shorter mufflers to compensate.
    bobss396 likes this.
  29. gimpyshotrods
    gimpyshotrods
    Thicker is not better.
  30. CadGuyUSA
    CadGuyUSA
    It is when it's the same butyl rubber, no?
