Carson top
Discussion in 'The Hokey Ass Message Board' started by ampsbad41, Jul 28, 2023.
  1. ampsbad41
    ampsbad41
    from Texas
    Have a question I have a 1941 Packard 110 coupe the body is complete ruff but all there nothing inside not enough to restore so I am thinking about making a custom .now I'm an old fart with big dreams but I want to try worst case ill sell parts i don't have much in it but I want to do a Carlson chopped top nothing radical . My question is do I need reinforcement when I cut old top off ?? Thanks in advance
    Sent from my SM-N960U using Tapatalk
  2. Moriarity
    Moriarity
    SUPER MODERATOR
    I moved this to the main board, the Q and A section is for questions about how the board works, also I am pretty sure you mean "carson" top. I changed the ***le for you
    dana barlow likes this.
  3. Generally speaking, the more strength in the frame for the top the better. That means using steel, and wooden popsicle sticks not so much.
    Reinforcing the ch***is rails, as per convertibles, is also on the menu.
    I'm not familiar with that model....... Is the plan to have a single, slightly shorter, gl***, roll-up window on each side?
  4. nrgwizard
    nrgwizard
    from Minn. uSA
    One thing that'll stick out like a sore thumb on an "ex" coupe-come-'vert, is the back of the w/s posts. On almost all cpe/sdn/etc, the post packs are curved, even a little. The 'verts are straight n flat. & the top of the w/s post bar is also flat, not curved back as iffen it just had the metal top cut off. Well, except for Huson ~ 48->48 +/- .
    Just a couple of thoughts. Good luck w/the project.
    Marcus...
    51 mercules, lurker mick and X38 like this.
