Technical Carter 1BBL throttle cable conversion help
Discussion in 'The Hokey Ass Message Board' started by SlmLrd, Jul 27, 2023.
  1. SlmLrd
    SlmLrd
    from DAGO
    Hi guys,
    I installed some Fenton dual headers on my 235 I6 and had to fab a trans pan as I went with a T5.. Ill need to add a new gas pedal and throttle linkage- would prefer to go cable and byp*** threading the bent rod through the headers. Any info out there?
    Thank you!
  2. chevyfordman
    chevyfordman
    I put one of those Lokar pedals that look like and original pedal. It has the cable on the firewall side but you have to make a hole at the base of the pedal for the cable pull mechanism. It is the smoothest working cable without any resistance to move. I really like it.
  3. Mr48chev
    These are shots of the actual Lokar pedal setup.
    I've got an ebay knockoff that I bought several years ago for my 48 with the 292 that I haven't tried yet. Years of driving with donor rig pedals that pulled a cable but were sometimes horridly uncomfortable taught me that I needed something that worked more like the original pedal on the inside. I just couldn't afford the Genuine Lokar pedal and have to gamble a bit. Screenshot (2000).png Screenshot (2001).png
    The all black one that Lokar sells would hide a bit better on the floor. Lokar XFMG-6098 Eliminator Floor Mounted Gas Pedal 835573008234 | eBay
  4. SlmLrd
    SlmLrd
    from DAGO
    Thanks for the pedal replies! I have that part figured out.. The challenge Im having is routing a pull cable to work with my rod push style Carter 1bbl linkage. Cant seem to find much info out there
  5. SlmLrd
    SlmLrd
    from DAGO
    thought of making a bracket to attach to the bellcrank, will post a pic this weekend
  6. vtx1800
    vtx1800
    not sure if you'd consider it but I purchased the same cable through Speedway, way longer than I needed but...maybe it would be long enough to go around and pull from the front side? Will it be old tech..no...but there I times I just want to "get er done":)
    SlmLrd likes this.
  7. SlmLrd
    SlmLrd
    from DAGO
    Yes, I could do that, but it would look terrible.. Im kind of a fanatic about fit and finish and things working the way they should. Im building this car to be a stunner, so Ill figure out a proper solution. Thank you for the reply!!
  8. Joe H
    Joe H
    I switched the way my Carter W-1s open by adding a lever to the throttle bracket. The lever extends across the center line so pulling down opens the throttle just as pulling up used to. I used stock 250 bell cranks with home made linkage rods. The cable pulls back, while the bell cranks pull down. DSCN2921.jpg
    SlmLrd likes this.
  9. SlmLrd
    SlmLrd
    from DAGO
    Thanks Joe! Interesting setup, looks great!... Geometry isnt my strong point, but I think I understand how it works. I ***ume you have no binding issues
  10. Joe H
    Joe H
    Smooth as a stock setup! Cable is something from a GM car I had around and throttle pedal came from Speedway. The hard part was getting all the play out of the linkage so they open the at the same time with no binding.
  11. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Bellcranks are your friend.
    Hillbilly Werewolf likes this.
  12. Kerrynzl
    Kerrynzl
    Carbs are easy to link together.
    On my old Lotus Cortina , I went to the local "U-Pull" and cannibalized a 1/4 round cable pulley [off an old Mazda 323]
    I welded it to the Weber throttle lever and had it re-plated to look stock
    The carb to pedal was as smooth as ****er and linear with the pedal [no progressive or over centering] which was perfect for driving at the limit of tyre adhesion.
    There are plenty of other candidates out there.
    SlmLrd and THE FRENCHTOWN FLYER like this.
  13. SlmLrd
    SlmLrd
    from DAGO
    beautiful setup
