Hot Rods carter 4594 fuel pump
Discussion in 'The Hokey Ass Message Board' started by birdman1, Jul 19, 2023.
  1. birdman1
    birdman1
    I got the gas tank installed in my 1960 Merc ragtop. I was thinking of using the carter 4594 electric pump. It says 4-8 PSI, so should work good with the Weber IDF48 carbs. Has anyone had any experience with this pump? i usually use the Holley electric knock-offs from Speedway Motors. They do work fine but are noisy. Thanks for any help.
  2. egads
    egads
    Whats wrong with using a stock pump?
  3. Beanscoot
    Beanscoot
    Weber carbs use rather low pressure fuel delivery, I've seen 3.5psi quoted as a factory spec.
    But if no one else beats me to it, I'll check the actual Weber Carburetor book this evening.
