Carter AFB carb guru's?
Discussion in 'The Hokey Ass Message Board' started by muddpile, Sep 12, 2009.
  1. muddpile
    muddpile
    from Canada
    I just purchased an offy dual quad setup, and it came with a pair of Carter AFB's, both of which are casting #D8 3721S3, which apparently is a factory carb for a 300hp 327 chevy in 1965, 575cfm. Both carbs need a full rebuild kit, along with some other things, such as linkages that are missing, chokes, etc etc. Is there someone on here who can steer me in the right direction on finding parts, and how to make this pair run on my 327? Thanks!
  2. arca39
    arca39
    from summit il
    well only one will have a choke, had to get both to work the same (all muti cabs ). as for parts, try speedway parts they will even have a progessive linkage set up. that is like orig.
  3. scottybaccus
    scottybaccus
    You will be surprised at what you can get across the parts counter with the right number. Don't call, carry them into a good parts house like NAPA, not a discount place (read Auto Zone).
  4. frankenstein1948
    frankenstein1948
    I was able to get kits for mine at NAPA. They had them in stock no waiting.
  5. twotoejoe
    twotoejoe
    PM Carbking. He posts on here, and he is the AFB guru! He also sells supreme kits for AFB's.
  6. carbking
    carbking
    DON'T PM carbking!
    He is too old :( to learn to use the PM's on all the various boards he frequents.
    On the other hand, he will be happy to talk to you if you call 573-392-7378 (9-4 central time Mon-Wed). And hopefully answer your questions.
    Jon (carbking).
  7. seetz
    seetz
    he IS great. one of the few people worthy of using the name 'king'
