Hot Rods Carter AFB ID
Discussion in 'The Hokey Ass Message Board' started by Vcen4cr, Apr 12, 2021.
  1. Vcen4cr
    Vcen4cr
    I’m trying to identify an early Carter AFB. only stamped numbers I can find are 37208 B
    And another stamped number is: 0-1552. I tried a cross reference chart but couldn’t find and exact match. 37208 plus an addition 3 numbers come back to a 1968 Chevrolet with a 327 pg. would like to know the cam and the proper number so I can revuild it. Thanks for any help or info. Jerry
  2. chessterd5
    chessterd5
    from u.s.a.
    If it comes back as a Chevrolet, it's probably a Rochester, not a Carter AFB. Pictures would help. I will let the experts comment on your carburetor.
  3. Vcen4cr
    Vcen4cr
    maybe a dumb question but the carb has “Carter AFB “ sand cast in the body. Would it still be a Rochester........are they the same as Carter. I agree, I think it’s an early 60s carb for a 327 but how would I order a rebuild kit. I have an A rpu with a 57 283 and a dual range hydro. It has a Rochester on it now. Just thought I’d try the Carter just for grins.
  4. ClayMart
    ClayMart
    A couple of pictures posted here could go a long way toward helping identify your carb.
    squirrel likes this.
  5. stillrunners
    stillrunners
    from dallas
    Most AFB/AVS early Carter's I have dealt with have only 4 numbers and a letter.
  6. greybeard360
    greybeard360
    Application
    • 1964 - 327/300HP Standard Transmission
    Specs
    • CARB: Carter AFB Carburetor #3721s
    • DATE CODE: ?
    • AIR CLEANER: 4.5"
    • GM #: 3851761
    • AIR HORN #: 6-1518
    • CASTING #: 0-1552
    • CFM 500
    302GMC likes this.
  7. bchctybob
    bchctybob
    The number is probably 3720SB. Carter AFB for 1965 327 A/T. Rochester 4 jet is a whole different animal.
    carbking and squirrel like this.
  8. carbking
    carbking
    As Bchctybob stated, 3720SB
    From my website:
    Carter numbering systems. Three different types of numbering systems are found on Carter produced carburetors.
    (1) On carburetors built for Chrysler Corporation, a series of 3, 4, or 5 letters and numbers; i.e. EV1 or D6H2.
    (2) On carburetors built for Ford Motor Company, the “Ford” numbering system which is “lnll – l(l)(l)” or letter, number, letter, letter dash letter (possible letter) (possible letter) i.e C5VF-A. This system is codified in that the first letter is the decade (B=1950’s, C=1960’s, etc.); the number is the last digit in the year; the 3rd and 4th letters (before the dash) represent the vehicle model (VF=Lincoln); and the letter or letters after the dash are a modifier which distinguishes the exact application. Thus in the example C5VF-A, the carburetor would have been the first application for Lincoln in the year 1965.
    (3) The traditional Carter numbering system which consisted of 1, 2, 3, or 4 digits; followed by the letter “S”, possibly followed by another letter. It is extremely doubtful that any of the single, double, or early triple digit tags will appear; as they were produced before 1930 and were constructed of red cardboard. The metal tag appeared about 1930 with tag numbers of about 300s. The 4 digit tag appeared in 1952, and was continued on until the end. The letter S and following letters, when present, have caused much speculation (mostly incorrect). In Carter’s terminology, an individual part such as an idle mixture screw was a single part; whereas two or more individual parts sold together such as a needle, seat, and gasket were sold as an “***embly”. Carter used the suffix letter S to denote ***embly. Since all carburetors are composed of multiple parts, the letter S was appended to all carburetors using the traditional numbering system i.e. 938s. If a significant engineering change was made to the carburetor, the letter “A” would be appended to the S (i.e. 938sa). A second change would have the letter A replaced by the letter B (i.,e. 938sb). The highest engineering change of which I am aware is 4 i.e.938sd. Contrary to popular belief, the S DID NOT mean standard transmission, nor the SA automatic transmission.
    Hope this helps.
    Jon.
  9. Vcen4cr
    Vcen4cr
    Air horn # matches 6-1518. Casting number matches 0-1552. 37208 B with a B7 below still no match but I think it’s narrowed down to the following posts. Sincerely appreciate all, the information provided Jerry
  10. carbking
    carbking
    The B7 is a production date of February 1967. SR carb.
    Jon.
    AHotRod likes this.
