Technical Carter Competition Carbs
Discussion in 'The Hokey Ass Message Board' started by R Sad, Dec 5, 2025.
  1. R Sad
    R Sad
    I have an Edelbrock c-26 manifold with Carter comp. series 500cfm carbs that I picked up a swap meet at least 25 years ago. Plan was to use it on Sbc 4 speed 35 Ford pickup. Since that project is on back burner have decided to run it on 383 Sbc in 59 gmc I hope to have back on the road next summer. I do realize that it will make more power with Holley 770 on it presently. I like the look of 2x4 setup and would like to get it in use and working while I’m still able to drive. Neither carb has any provision for a choke. The holes in carb top and air horn are not drilled. Have looked on line for used carbs matching these with choke. These are 4000 series carbs and in 500cfm haven’t found any. I don’t plan much cold weather running, so am I worrying about a non issue. Opinions welcome. I have also wondered if Carter sold carbs as pairs for 2x4 setups. Carb numbers are k1 4761s and L2 4761s. I apologize for no pictures. Have to get my sons help with that. I appreciate any input. Have read that I will need to run phenolic spacers to keep fuel from boiling. Reposting I hope in right place. Thanks
    Toms Dogs likes this.
  2. saltflats
    saltflats
    from Missouri
    I have a pair of 750s of that series that one have provision for a choke and not the other. I would think they made 500s also.
    mad mikey likes this.
  3. R Sad
    R Sad
    Salt flats thanks for the reply.
  4. saltflats
    saltflats
    from Missouri
    Look for a 4768 that would be a rear carburetor for the front's you have. Just found my catalog from 1969.
  5. bchctybob
    bchctybob
    There’s more to it than just the choke bolt holes, there’s the shaft and ****erfly, fast idle cam, links and a choke unloader lever, IIRC. You might be better off to buy a cheap 625 cfm or something to harvest parts from.
    But you mostly need to ask yourself if you really need a choke in the first place. With a good ignition and two properly functioning AFBs one or two squirts and it should fire right up. You may have to act as a “human fast idle cam” for a few seconds but…..
  6. 19Eddy30
    19Eddy30
    from VA
    Average 383 10:5-1 ,1000 CFM is plenty.
    Choke
    Tuned correct , No choke Needed ,
    Just need to lean what engine needs when starting cold .
    Are heads 200 cfm''s plus
    2.050 Vavles, & bigger .
    Cam in ..570 ish plus
    If "" Looking for Performance""
    instead of Eye candy.
    Vic Ram & Holley Strip D more superior over the C-26 if in 470 hp plus,
    Really a single Team G , Holley Strip 3 different intake's open plain for 450 - 600 hp
    1 6,500 to 7 short
    2nd 8,500 medium
    3rd 10,000 Tall
    26 is basically a dual plane 5,500 & like
    460 hp ,
  7. tomcat11
    tomcat11
    The matching 500cfm carb with a choke for the Carter 4761S is 4758S . It has a manual choke. So no fast idle cam or unloader is needed. You will probably be fine with a pair of 4761's
    rod1, mad mikey and AccurateMike like this.
  8. 1biggun
    1biggun
    Unless your driving it in the winter id not worry much about the chokes if you have a matched set run them and see how it works out .
    Had twin carters on a BBC and never had chokes working.
  9. R Sad
    R Sad
    2x4 going on a GM zz383 . Engine is still original spec. I really always liked and wanted a 2x4 setup. Looks. Think it will be enough for this engine.
  10. mad mikey
    mad mikey
    Sure, should work very well properly tuned.
    Bill's Auto Works likes this.
  11. bchctybob
    bchctybob
    Carbking on here is a wiz with AFBs and a big fan of dual quads. He has probably setup a few Chevy 2x4 setups in his career. Maybe he will chime in. If not, send him a PM but be prepared with all of the pertinent information.
    You are lucky to have two unmolested 500 cfm Carters, most have been rode hard and put away wet by now, with stripped threads and mix-matched parts. Jon sells premium rebuild kits with the leather accelerator pump plungers.
    Bill's Auto Works and mad mikey like this.
  12. carbking
    carbking
    OP opened two identical threads, for the benefit of those reading, here is the other thread:
    https://www.jalopyjournal.com/forum/threads/carter-compe***ion-carbs.1344812/
    OP - yes, the two 500's will be sufficient for your 383. :)
    And, while I realize that most of the folks who read these boards are independantly wealthy ;), thus literally have money to burn :p; running without chokes on a street driven engine causes the burning of money (exta fuel) ! :( The choke ****erflies act as "straightening vanes" and improve the air flow, thus the efficiency, at lower RPM. :) Both driveability and fuel economy will be improved. :D
    Jon
  13. 19Eddy30
    19Eddy30
    from VA
    Yes & No , When OEM Designs there looking @ Customer , Try to accommodate DD & Performance,
    Can you imagine how many complaints
    & Bad talk from customers not able start there new car when cold , or flooding spark plugs ..
    The average dual Carb or single the clearance between top of air cleaner &
    Choke horn , Compared to fresh air into,
    Very restrictive . There was Not to many Manufacturers Won on Sunday Sold on Monday customers Purchase/ received what they paid for performance wise .
    Velocity stacks / Air Bell's cure & incorrect air flow Over Oem @ that time.
    The C-26 going to make a Lot of Noise when all 8 kick in , make you feel by seat of your pants fast & Hp ,
    We do not Know if this is a 383 480 hp
    Or 550 plus So intake Selection is critical for Performance or just for looks,
    If 550 hp 1,000 cfm's good , Not the
    C-26 intake , If 480 Eye candy & suitable , A Team G low rise with
    750-780 better choice but not dual ,
    If I was to build from scratch under
    400 cid for performance I would do
    377 , good parts non **** ,
    200 plus cfm heads maybe 18 deg
    North of 7,500 - shaft rockers
    Quality pistons rods crank[
    Very restrictive . There was Not to many Manufacturers Won on Sunday Sold on Monday Purchase/ received what they paid for performance wise .
    MC-26 intake , If 480 Eye candy & suitable , A Team G low rise with
  14. 1biggun
    1biggun
    Can you recommend a source for good rebuild kits for the Carter and Edelbrock carbs besides the expensive Edelbrock kits for the Edelbrock carbs??
    I wonder if a simple plate rigged could serve to straighten air for the existing carbs .
    Thanks.
    I never had any real drivable issues on the BBC i had twin non choked carter's on but that dosent mean maybe it wpuld have ran better . It was also geared pretty low and had a stick
    Does make me think however.
    bchctybob and Sharpone like this.
  15. carbking
    carbking
    Carter made 505 different AFB carburetors, for which we make 112 different rebuilding kits.
    We don't make anything for the edelbrocks.
    Jon
  16. 1biggun
    1biggun
    I would be happy with a quality needle and seat option for the Edelbrock.
  17. I have a pair of those on a low rise Pontiac dual quad manifold that I bought some years back, never looked to see if they have choke plates as I never took off the air cleaners. Will look tomorrow
    I never run a choke on something hot with a stick. Stubby has a pair of the Quick Fuel carbs with no chokes on a high rise manifold, the damn thing starts too quick. I like it to spin a time or two to get the oil going:p....I would not worry about it at all.
    God Bless
    Bill
    https://www.jalopyjournal.com/forum...ar-transport-hauling-open-or-enclosed.614419/
    mad mikey, bchctybob and saltflats like this.
  18. swade41
    swade41
    from Buffalo,NY
    I've been running a pair of 600's with Offenhauser low profile on top of a mild 350 for 18 yrs, chokes wired open. I have no issues without chokes and live in the cold place of Buffalo NY.
    My only complaint is that the fuel bowls evaporate so if you let it sit for a few days you'll have to crank and pump until it picks up fuel. Now of course if you have an electric fuel pump you won't have that issue.
    I do have a spare setup C26 with 500's on the shelf, they don't have chokes either and have driver's side fuel inlet, the 600's are p***enger side.
    I have a couple other 2x4 cars but with Holleys, they don't have chokes either and again no issues.
  19. swade41
    swade41
    from Buffalo,NY
    I think that says 4758 on mine ???
  20. R Sad
    R Sad
    Your 500 cfm carbs do have holes drilled for choke shafts. Mine don’t and so far haven’t found any 4000 series carbs like I need. 9000 series top plates are different. Found carb that was right but looked so corroded I couldn’t use it. I have looked at a couple of Edelbrock carbs I have no money in and they have the top that matches the 9000 series I believe. Looks like the choke parts off the Edelbrock would work. May look into having shaft holes drilled.
