Trying to link a picture. Wondering if these are the kind the mechanical pump on a Ford can draw fuel through. Thanks! https://www.jegs.com/images/photos/100/180/180-p90091.jpg
It should work since it will send fuel to the pump and then the pump will push it forward to the carb. Would be helpful if you provide year and make of car, engine size. Make sure you get a pump that provides the correct pressure.
This is the one I have on my rod, to supplement the mechanical pump, when needed. https://www.amazon.com/Carter-P4070...hvlocphy=&hvtargid=pla-4583589114774203&psc=1
