Carter fuel pump ID
Discussion in 'The Hokey Ass Message Board' started by Model A Mark, Nov 24, 2012.
  1. Model A Mark
    Model A Mark
    from dallas
    Hey guys, I need a low pressure pump to run with 2 8BA carbs on my flathead in my 50 F1, I have this old Carter pump, but dont know how much pressure its goanna put out.
    Naturaly I cant find any numbers on it.
    I was hoping someone might reconise it and know the specks for it.
    Also I bought this speedway made in koriea Holli pressure regulator to get the final pressure down to 3 psi, do you think it will turn a high pressure pump down that far ?
    Iv got the same regulator on my roadster but the pump only puts out 9 psi.
    Thanks
  2. kennkat
    kennkat
    The pump in pic #1 should be about 7 psi max, I think Carter shows them at 4 - 6 psi... The pump in pic 2 is one I use for a transfer pump, Its application was a 6.5 GM diesel primary fuel pump. Again it is a low pressure pump, never measured it but I have no problem stopping the flow with my thumb....:D:D:D
  3. Marty Strode
    Marty Strode
    The first pic looks like a Carter P-4070, great pump, and the 3lb regulator should work fine.
  4. Model A Mark
    Model A Mark
    from dallas
    Thanks guys very much.
    So should I mount the pump as close to the tank as possible ?
  5. kennkat
    kennkat
    Yes, and low not above the bottom of the tank:):):)
  6. Marty Strode
    Marty Strode
    Mark, Make sure you install a filter between the tank and the pump, and mount the pump as reasonably close to the filter. I use the steel canister, inline type. When they are close to the frame, I cut 2 bands off of some radiator hose, and slide them on for anti-rattle.
  7. kennkat
    kennkat
    YES!, that's how...:):):) Very nice.
  8. Model A Mark
    Model A Mark
    from dallas
  9. Randy in Oklahoma
    Randy in Oklahoma
    from Oklahoma
    Be careful...Back in the day I had an electric fuel pump on a drag car. Fuel line came loose in my driveway as I was adjusting the valves. This was a high volume Carter pump, and it puked about a quart of gas all over the engine compartment before I realized what was going on. Caught fire, and I ended up ruining a gl*** hood, bumper, wiring, and my pocket book !
    You couldnt give me an electric pump, unless it was an OEM type for modern fuel injection.
  10. Model A Mark
    Model A Mark
    from dallas
    thanks for the imput randy, but im running a regrind " pitvin 3/4 race" cam in my flathead and the fuel pump lobe is worn off the cam, i have no choice.
