Carter Two barrel Carb?
Discussion in 'The Hokey Ass Message Board' started by Drive Em, Nov 4, 2009.
  1. Drive Em
    Drive Em
    I recently bought an O/T one owner 1967 Falcon wagon with 81,000 miles on it. It has the "C" code 289 that is un-molested. I popped the air cleaner and was expecting to find an Autolie 2100 carb, but to my horror, there is a Carter two barrel carb. I have never seen one of those carbs before, and was wondering if it was any good, and where to get a kit for it as there is no tag on the carb.
  2. BOBCRMAN
    BOBCRMAN
    from Holly
    Chrysler used BBD Carters in the sixties. Check there for kits.
  3. REJ
    REJ
    from FLA
    If it is a Carter BBD, there is nothing wrong with them.
    Autozone has the kits to rebuild, just tell them it is a BBD carb and most of the kits will work.
    The only thing different in the kits is the way the accelerator pump is attached. Make sure you get the right one there or you will not be putting a new pump in it.
    Robert
  4. merf
    merf
    from new joisey
    Might be a Carter ABD,that will bolt up to an Autolite bolt pattern. They were used on Lincolns.
  5. carbking
    carbking
    Carter offered several different 2-barrel carbs over the years.
    The ABD (as previously mentioned) was designed for Ford products, and bolts to the original Ford manifold. Excellent carb, parts readily available via mail order, probably not locally available.
    The WCD will not fit the Ford manifold, otherwise excellent carb. Parts availability a little better than the ABD.
    The WGD (top of the Carter line). Parts availability like the WCD
    The BBD (Carter's entry level two-barrel). Useful (my opinion) only on original numbers-matching vehicles. Parts readily available (and you will need parts!). However, no performance parts, and no information on performance modifications, and VERY difficult to modify for performance work.
    Jon.
  6. carbking
    carbking
    Just reread the second part of your question:
    ABD has a stamped number on the airhorn which will be 4 digits followed by the letter S as in (S)am.
    WCD and WGD were identified by tag; however if the tag is missing, may be identified by use of the code number stamped on the underside of the cast iron flange, and the number cast on the metering rod.
    BBD was identified by tag only. If the tag is missing; identification is virtually impossible, and the cost to do so would certainly exceed the value of a new carburetor.
    Jon.
  7. PegLegStrick
    PegLegStrick
    Never had a problem with the Carter on my '54 Poniac. I think I'll keep it
