Technical CARTER W1 identification help
Discussion in 'The Hokey Ass Message Board' started by fafaniruzik, Apr 27, 2016.
  1. fafaniruzik
    fafaniruzik
    Hey everyone,
    About to pull this guy off and give it a deep cleaning after its long slumber in a barn. Its from a 47 or 48 Chevrolet Thriftmaster. Having trouble ID'ing the carb and which rebuild kit i should buy online. Does anyone have any experience with these and might be able to ID it? I attached pics below. If i need to tear it apart to ID it i guess i can do that. I just dont like the idea of starting something and then not finishing it while I wait for parts to come in.
    Thanks!!
  2. ClayMart
    ClayMart
  3. shelby1965367
    shelby1965367
    Try mikes carb parts online, he can get you the correct parts for that carb, there are I think 3 different rebuild kits for the w-1
  4. fafaniruzik
    fafaniruzik
  5. Road Runner
    Road Runner
  6. oj
    oj
    When you get it clean look at the cast iron base, if it has the casting #603 then it is carb #684S; if the casting #432 then it'll be carb #616S 'Fleet Economy Model'
    Carter was **** about making specific carbs, it could be one of a few others too. I would imagine the basic parts will interchange, just be careful with the spring that holds the metering rod under that big cover. The springs are hard to find.
  7. 6inarow
    6inarow
