Carter W1
Discussion in 'The Hokey Ass Message Board' started by W7365, Jan 13, 2013.
  1. W7365
    W7365
    I have a stock '34 Chevy with a Tillotson carburetor that leaks. I believe the Carter W1 was stock on this car, so will any W1 fit or do I need to find a W1-284S? There seem to be a fair amount of W1's around but I am not sure how they differ. This will be a driver so matching numbers are not important. Thanks. Kevin
  2. fnla39
    fnla39
    The mounting flanges are different. I have 2 that won't bolt up to a Chevy intake. Best to look for one made for the Chevy.
  3. Road Runner
    Road Runner
    Chevy 1934 stock carb was Carter W-1 284s (Master) and 285s (Standard & Truck)
    In 1936 Carter recommended the 569s to replace all 1932-1936 carbs.
    Other models that fit 1932-40s Chevy (and considered upgrades to Carter W-1):
    Zenith 28 (10354 A, 10355 A)
    Stromberg BXOV-2 A-19122 (14-17D)
    Stromberg BXOV-25 A-19123 (14-16F)
    Stromberg BXOV-25 A-19132 (14-16G)
  4. they had 2 different bolt paterns on the bases i switched them when i dualcarbed my 54 chev eons ago
  5. carbking
    carbking
    Not trying to step on anyone's feelings, but as far as I know all Carter W-1 carbs have the same S.A.E. size 2 mounting flange (mounting bolt center to center is 2 11/16 inches).
    Here is a link to an article that may help:
    http://www.thecarburetorshop.com/CarterChevroletW1.htm
    There can be some issues with attaching the mounting linkage if using a later carb on an earlier engine. As mentioned by Road Runner, the 569s was used as both a factory and aftermarket replacement for the 1932~1936 carbs. The 569s was released in 1946. Basically, the 569s is a 574s (1946~1948 Chevrolet) carburetor with a 1932~1936 throttle arm.
    If you don't mind playing with the linkage, the three best (other than the aforementioned 569s) of the W-1's to use would be the 420s (1939-1940), the 483s (1941-1942), and the 574s (1946-1948).
    The 684s (1949 only) is an excellent carb, but virtually all of the parts for the 684s are made out of verypricium! Should you opt to ignore this advice, I have all of the parts! ;)
    While all of the W-1's have the same base mounting (Carter also made a W-2, with the S.A.E. size 3 base); the later YF carbs had different (both size 2, and size 3) bases.
    The number following the type (for the most part) on Carter carburetors identifies the S.A.E. size; but the numbers are off one size. Thus a WD-0 or a W-0 is a size 1; a W-1 is a size 2; and a W-2 is a size 3.
    Jon.
  6. jtrod49
    jtrod49
    After doing some research I believe I want to run 3 carter w-1 on my 235 with a Nicson intake.... I was reading along here and wondering if u can point me in maybe which carbs I should consider and where I can find them hahaha thanks Jarrett
