Technical CARTER YF REASSEMBLY HELP [edit - resolved]
Discussion in 'The Hokey Ass Message Board' started by tjet, Apr 28, 2023.
Tags:
  1. tjet
    tjet
    I'm attempting to reassemble my Carter YF 1 barrel carb, but I'm having issues keeping the rod in place. The little spring that secures it keeps pulling it out of the jet.
    I'm wondering if there's a trick to keep it lined up so I can get the top of the carb back on.
    Thanks
  2. tjet
    tjet
    Disregard, I had it****embled incorrectly. The arm that holds the rod was on top of the upper spring. It needed to be on the bottom.
    Correct now.
    Truckdoctor Andy likes this.
  3. ebs121781
    ebs121781
    from Spring, TX
    I have the spec sheets and diagrams for a bunch of different YFs. Shoot me what model you have, I'll send you a pic or scan of the sheet for it for reference, if you want...
